Oil pump questions
Old Dec 4, 2002 | 02:37 PM
SRVFAN7's Avatar
SRVFAN7
Default Oil pump questions
Building up a 350 for those of you who don't know =) Have a couple of questions about the oil pump... I'm goin with the malling high volume. I understand that it would be a good idea to go with a deeper pan. So I'm thinkin about the moroso 7qt. Will this fit into a camaro? Also which pickup would i need to get and where? Last question... What about the shaft? Will I need a new one? I think there is still one in the block i bought thats stripped to only the bare block. Any advice is appreciated! Thanks...
-Tony
Old Dec 4, 2002 | 03:00 PM
mountainmotor's Avatar
mountainmotor
Default Re: Oil pump questions (SRVFAN7)
You will need a new oil pump drive because the HV pump take more force to turn it
You will need the Moroso pickup tube to match the oil pan. I really would call them first for part numbers.
If you are not building a hi-rpm motor with loose clearances a stock oil pump,pan and pick-up will do fine,,still need the one piece drive imo and the oil pump mount stud instead of a bolt.
I've run the race motors over well over 8k with 30lbs of pressure. Now they don't idle long or with much pressure as in 5lbs!
Old Dec 4, 2002 | 03:53 PM
SRVFAN7's Avatar
SRVFAN7
Default Re: Oil pump questions (mountainmotor)
This is gonna be a high rev motor and have the whole thing pretty much tight. Thanks for the info. I've already picked out a stud for the pump. Whats the one piece imo? The shaft I was looking at then to get was the ARP one. Is this a good one or is there something that works better?
-Tony
To Oil pump questions
