DD2000 Question
Old Dec 11, 2002 | 05:51 AM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Default DD2000 Question
How would I determine what the results of 1.6 and 1.7 rockers in DD2000? Is there a way?
Old Dec 11, 2002 | 08:37 AM
Caboboy's Avatar
Caboboy
Default Re: DD2000 Question (Guru_4_hire)
Thats a good question. What I've been doing is changing the lift value in the cam field, for example:
The cam I'm modeling has a .518 intake lift with 1.5 rockers. The formula is [lift times 1.6 divided by 1.5]. In my case the new value is .553
I'm not real good with the program though, we'll see if I'm making the right adjustments when others chime in :cheers:
Old Dec 11, 2002 | 10:19 AM
gkull's Avatar
gkull
It's simple math: Cam lobe lift X the ratio of the rocker arm. You will find that DD2000 has negligible gains with lift increases.
To DD2000 Question
