Ceramic Coating
When do we get to see some vids of this thing running?
I was looking at dougs TT web page and he posted some videos last night. They have me all pumped up now. These TT V8's rule!
I just got my wife a digital camcorder for Christmas, so as soon as the novelty of it has worn off for her, I'll try to get my hands on it and take some videos.
I'm either going to install the "Sharkbar" or build my own rollbar/harness bar, either way it will include a camera mount. I'm dropping the headers off tomorrow to get coated, turn around is a week, so I should have it all together on about 2 weeks. In the meantime, all that needs to be done to the car is to put the seats back in and finish plumbing part of the power steering system. After that, it just depends on the weather here in Chicago. Realistically, it will probably be March or so...
As for TT V8's, they are pretty cool. I still can't believe how the same engine can idle and drive so smoothly around town, but as soon as you hit the throttle it just jumps to life. 700 ft lbs by 3000 rpm with a 3200rpm stall means that the power and torque are right there when you want it, and it keeps coming harder all the way to redline. I haven't driven it on the street with more than 5-7# boost and it's too much, I can't imagine driving it with the 20-22 psi of boost it's tuned up to.
[Modified by Monty, 7:02 PM 1/7/2003]
Lots of coatings like.......
Plasma sprayed Zirconia Titania Yttria Ceramic Composite Coating over a Nickel Aluminium Bond Coat :eek: ( Piston ring)
3 yrs if inside and out are done.
My headers were purchased with an outside coating, but after a few yrs.
the coating started to crack. :cry
The headers are custom made 16 guage 321 stainless steel, fully TIG welded, so they'll last forever. The stainless steel is almost as effective as coated mild steel at not radiating heat, and since it's stainless it won't rust either way. The only reason I'm coating htem now is to match the appearance of teh other coated components.
I just dropped the headers off yesterday to get coated, along with the sway bar linkage I made(getting powder coated). The owner says he's done alot of turbo headers and he usually coats the inside as well. I asked him about possible turbine damage and flaking coating, and he said he'd never heard of that. However, I have read/heard people claim that flaked off ceramic coating from inside the headers damaged the turbine wheel when the flakes passed though it. I just played it safe and told them to coat the outside only.
I personally wouldn't go with mild steel, I'd go with cast iron weld els first, but there are plenty of guys out there running mild steel turbo headers and they seem to work pretty well and last. To be honest, some of the "junk yard" turbo projects amaze me. I' certainly no expert welder or fabricator but some of the stuff I see out there is pretty scary. But hey, if the thing runs 10's and makes a 1000hp, who am I to say....
I know a couple of people who have been running custom turbo setups for as long as 5-6 years using the same 321 stainless I did, and they're headers look the same as mine - no cracking, sagging, etc.
I bought most of my stuff from Specialty Products Design, they sell the same stuff as Burn's, just a different name, but I do have some materials from Burn's. Their prices are about the same as well.
The key to making your turbo headers last is to use good materials like 16 gauge 321 stainless, good/clean welding(TIG preferred), accounting for thermal expanision by using long smooth bends, slip joints, or expansion joints, and supporting the turbo so that the weight is not supported by the headers.
If I ever build another set of headers, I'm going to use Burn's double slip joint collectors. they're like the one's I have, with a 15* merge taper witj a cone inside, but they have a slip joint to account for thermal expansion. If you can reduce the stress on the headers, they wion't crack and will last forever.
[Modified by Monty, 9:08 AM 1/11/2003]
I just got my headers back today....
