Kudos to Comp regrading backing up the lifter problem
They also confirmended the problems with the Endurex lifter.
It took me about 5 1/2 weeks to receive a set of retro roller rockers for my 383 buildup.
They said if I ran low lift, low spring pressure roller they would live forever. That's cool, but the whole point of a performance roller is to have faster valve action and the ability to achieve high lift without excessive wear. Kind of defeats the purpose. I wanted a "weenie" cam I'd put in a regular solid flat tappet and go forever! I could install a good long lasting flat tappet that would spank that little roller all over the place.
Hopefully, someday we will have a roller setup that canlive a long time in HD applications. I guess it's Shubecks otherwise. Anyone running them yet?
JIM
You're OK.......In fact perfect......for the type of cam you need, it would be useless to spend the money to run a smaller street roller. The performance you are seeking is available in a dead reliable flat tappet.
That's what I meant....Comp would have you install a cam mild enough to make their Endurex rollers live. Kind of seems backwards to me?
I know you were just picking on me....sometimes I speak in language that other folks might take negatively!
Good luck with your project!
JIM
I agree there is no reason to run a solid roller on the street unless you are trying to squeeze the last little bit of your motor. Or if the motor is so big a solid flat tappet will not provide enough valve lift to compliment the big motor.
My last solid roller would get its butt kicked by an aggressive solid flat tappet. The one I have now is a pretty aggressive roller, hard to match with a streetable flat tappet.
Of course price is one issue...the first price I heard was in the $900 range for the lifters plus the cam has to be coated with a special process to run them too they said. I'm really not sure if you can have any cam coated or if you have to use a Shubeck proprietary deal. If so, I would guess choices might still be narrow.
IF they really hold up, the savings would pay for itself over the long run.
I guess I need to do some more homework!!!
JIM
I have one of their street roller cams (236/242 @.050) with the Endure-X lifters (888-16). This is in my good weather daily driven '69 and I've put 15k miles on this combo with no problems. I may pull my intake this weekend just to take a look.
As far as no reason to run a street roller, what is the disadvantage of solid street roller over a hyd roller (other than setting the lash)? The solids have slightly more agressive lobes than their hyd rollers while still allowing relatively light spring pressures.
I also don't understand how the hyd roller lifter can last forever while the solid ones can't.
As far as no problems, are you running a small or big block, I am curiuos becasue I have not heard any problems with small blocks.
Hydraulics last longer because they are not subjected to the ramp opening rates of a solid roller and more importantly the hydraulics get oil down to the critical parts to lubricate them, the thing that killers solid rollers is lack of oil to the whell bearing and out wheel assembly.
The drawback to run a solid roller on the street is when one lets go, sometimes it will cause several thousand $ before you shut the mototr down. They do not allow for light spring pressures, they demand high spring pressures, this of couse is dependant on the lift, ramp rates, durations, rpm, etc. But as a rule the higher lift, rpm, etc, you must run high spring pressures. In most motors a hydraulic roller will make within a few % of the solid roller.
[Modified by BeaterShark, 5:10 PM 1/13/2003]
