WPC Treatment
Old Oct 28, 2023 | 03:13 PM
Sicari's Avatar
Sicari
Cruising
Default WPC Treatment
Has anyone either contemplated, or has had any WPC Treatment on any parts of an engine build? If so which parts (crank, pistons, cam, etc.)? Would you recommend it for a power added build? Also can you elaborate on weather the cost, and extended durability justified the means.
Best,
Joe
Old Jan 9, 2024 | 11:58 PM
John S 1961's Avatar
John S 1961
What is WPC?
Old Jan 12, 2024 | 05:11 PM
Sicari's Avatar
Sicari
Cruising
It's a metal treatment similar to shot peening with smaller projectiles at high velocity. It was developed in Japan. Here are a few links.
https://motoiq.com/Special-Treatment...now-about-WPC/
https://www.motortrend.com/how-to/tu...wpc-treatment/
Best,
Joe
Old Jan 12, 2024 | 10:18 PM
John S 1961
Shot peening has been proven to increase longevity in fatigue applications. But it's for racing engines.
Old Jan 29, 2024 | 10:11 PM
AZSP33D's Avatar
AZSP33D
It's expensive, I've done an SBC roller camshaft a few years back and I think it was $180. Removed it last year and it was in fine condition with regard to the WPC treatment. Also some motorcycle parts (Ducati Superbike Desmo Valve Train) and it's holding up great, virtually no adjustment needed but I keep the revs reasonable.
It's micro shot-peening that reduces friction and produces a more wear resistant surface.
To WPC Treatment
