CC'ing Combustion Chambers?
Old Feb 26, 2003 | 12:18 AM
bence13_33's Avatar
bence13_33
Default CC'ing Combustion Chambers?
I was looking on Jeg's site and they sell a buret that allows you to easily "cc" your combustion chambers but it sells for like $109. Is there anyway I could use just a regular scientific mL buret? Is there a cheaper way to "cc" my combustion chambers then purchasing this from Jeg's?
[Modified by bence13_33, 11:19 PM 2/25/2003]
Old Feb 26, 2003 | 06:51 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Default Re: CC'ing Combustion Chambers? (bence13_33)
It's not pretty or scientific, but you can get real close.
Go find a feed store, veterinary supply, anything that messes with horses or cows.
Get a 100cc syringe for a couple of bucks. It has 1cc graduation marks. Get you a piece of thick plexiglass big enough to cover a chamber and drill a hole in it in an area that will be close to the edge of the chamber. Put a little grease around the chamber edges to seal it. Fill syringe and put as much as needed into the hole. Tilt head as needed to allow air to escape.
You can use water, but it's a little "elastic". Alcohol with a dab of trans fluid for color works well.
It's the exact same principle and can achieve remarkably accurate results if you are careful.
You can also get smaller 50cc syringes that have a larger graduation scale so you can "sneak" up on correct amount easier.
JIM
Old Mar 1, 2003 | 08:04 AM
nastee383's Avatar
nastee383
I used a syringe I had left over from a hospital appt. I propped my heads up and used a small level to make sure they were level. My chambers were supposed to be 72cc's. That's what I got on all 8 using alcohol. I'm sure it wasn't exact but probably real close.
Old Mar 1, 2003 | 01:45 PM
Chuck Harmon's Avatar
Chuck Harmon
Default Re: CC'ing Combustion Chambers? (427Hotrod)
I did what 427Hotrod did. Take that significantly above average girl of yours out for a couple dinners with the $100 you'll save!
Chuck
Old Mar 1, 2003 | 02:28 PM
bence13_33's Avatar
bence13_33
Default Re: CC'ing Combustion Chambers? (Chuck Harmon)
Chuck:
That's exactly what I plan on doing! :D I purchased a 100mL lab buret for $10...and as it turns out 1mL=1cc. Not a bad deal at all :).
Old Mar 2, 2003 | 05:49 AM
arnold's Avatar
arnold
Certainly. Bought mine from a medical supply, back when 'kits' were not available. To be accurate, the graduations should be in .2 cc. Mounted it in a clamp clamped to a vertical rod mounted on a heavy plate. It is also important to have a clear plate that is sturdy enuf not to flex. I use a 1" clear plexiglass plate, although that thickness is a bit overkill. Easier to get accurate readings with the chamber slightly tilted to keep air bubbles out. Also obviously important to make sure you have a watertight seal from plate to head, valves, and valve in burette. Each drop is important to be really accurate.
Old Mar 2, 2003 | 08:06 AM
Flareside's Avatar
Flareside
Shane, it's basically the same thing that you're doing, but Comp Cams sells an "ecomony" cc kit for like $40 at Summit/Jegs. I bought one, and it worked fine for chambers and pistons. It's just a graduated cylinder and a Lexan plate.
To CC'ing Combustion Chambers?
