Not your normal head questions, so some can be releaved...
My question has to do with the design of a normal SBC head.
Why is the head/manifold port rectangular? Seems to me a round hole all the way would flow smoother. But I honestly know nothing about the sciences of air flow (Fluid Dynamics is it?)
Anybody out there able to give a reason why its square?
On the TPI motor it goes from round (runners/manifold) to square, to round (valve) that to me makes no sense, and is what caused this pondering...
There may be more and better reasons, but "packaging" is certainly one. The gen I ports can only be made so wide before they run into the push rod holes. If they were round, that would severly limit their cross sectional area. Also, not being a fluid dynamics expert, I share your thoughts on the round shape. For one, the surface area to volume ratio is optimized in a round "tube". An OHC set up would clear some available space.
