Reading through the archives it seems the Victor Reinz 5746 is the gasket to use for these Aluminum 58 cc heads. Was curious if these are pre-compressed to eliminmate brinelling on the head surface. Anyone have another head gasket reccomendation.
Re: L-98 Cylinder Head Conversion - Which Gasket ? (69stingray)
Use the Victor Reinz gasket. You can buy it really cheap from Competition Products (do a websearch for them). They sell them for about $14.00 each. Disregard the Lingenfelter recommendation because you're likely to have a .015 to .024 piston to deck height (how far down in the hole the piston is at the top of its stroke). If you install a .051 thick gasket it'll be octane sensitive due to a ridiculous quench (.066 to .075). The piston to deck height added to the crushed gasket thickness is your quench. The Victor Reinz works good with the piston to dech heights you're likely have. If, on the other hand, your block has a zero deck height, The .051 might be a good choice, although I'd still shoot for a gasket to give you a quench in the mid to upper .040's. But that's just my opinion.
I run a 383 in a 3/4 pickup that has 10.5 to 1 compression with aluminum heads right now. I can haul anything I want anywhere I want with 92 octane and it never ever pings. Getting the quench right makes a big difference.
Re: L-98 Cylinder Head Conversion - Which Gasket ? (CHarris85Vette)
Cory
:iagree: :iagree: I have the piston flush with the deck and use .039 thick gasket. .050 on a stock deck height will detonate. Quench is very important you can install thick gasket to lower compression and actually make it more prone to detonation than when the c/r was higher. :yesnod:
Re: L-98 Cylinder Head Conversion - Which Gasket ? (jackson)
I looked up that gasket in the VR catalog. Its is for a vortech head on a late model Chevy/GMC truck which is an iron head. The fire ring on thise heads is not precompressed, anyone every have a problem with brinelling the sealing surface on their aluminum heads ? The machine shop that did thr heads suggested a Fel Pro 1003. Will try them and see what happens.
