SBC dipstick fit
Old Apr 8, 2003 | 09:38 AM
GRX's Avatar
GRX
Default SBC dipstick fit
Should the 350 SBC dipstick be an "interference fit" into the block? Mine is sort of loose. Should I use RTV? TIA !!!
Old Apr 8, 2003 | 10:44 AM
Lohkay's Avatar
Lohkay
Default Re: SBC dipstick fit (GRX)
I don't know if it should be that way, but mine is very tight. I think its taper but I'm not sure.
Old Apr 8, 2003 | 08:24 PM
CFI-EFI's Avatar
CFI-EFI
It should be a "light" press fit. A few taps with the hammer, type of fit. I would see what you can do about expanding it a little. I've used RTV in the past, but keep it all on the outside. Don't let any get into the engine. Good luck, and...
RACE ON!!!
Old Apr 9, 2003 | 08:09 AM
LD85's Avatar
LD85
Default Re: SBC dipstick fit (CFI-EFI)
RACE ON!!!
:iagree: Just took mine out and had to tap it several times
To SBC dipstick fit
