can a pressure plate be resurfaced?
Old Apr 9, 2003 | 05:48 AM
Turbo-Jet's Avatar
Turbo-Jet
Default can a pressure plate be resurfaced?
http://forums.corvetteforum.com/zerothread?id=533726
thanks :cheers:
Old Apr 9, 2003 | 08:33 PM
ram82fire's Avatar
ram82fire
Default Re: can a pressure plate be resurfaced? (Turbo-Jet)
In a word ,,,,,,,,,,,, yes !
g
Old Apr 22, 2003 | 03:56 PM
wallyknoch's Avatar
wallyknoch
Thats exactly what a rebuilt clutch is. No job for an amature however. :)
Old Apr 22, 2003 | 05:22 PM
LD85's Avatar
LD85
Default Re: can a pressure plate be resurfaced? (wallyknoch)
I just had mine resurfaced, took off @ .060" I think, i can measure it if you need to know.
Old Apr 22, 2003 | 09:06 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: can a pressure plate be resurfaced? (ld85)
I hope anyone's consideration of surfacing the pressure plate, takes a complete rebuild into account at the same time. By only surfacing the pp, the springs will be working in a new, further extended, position. The longer "working" spring height will decrease the amount of pressure exerted on the clutch disc. Also, like brake drums and rotors, the pp absorbs and dissapates heat. A certain minimum mass must be retained. Good luck, and...
RACE ON!!!
To can a pressure plate be resurfaced?
