Nitrous on a 383?
Old Apr 10, 2003 | 01:33 PM
vetteguy216's Avatar
vetteguy216
Default Nitrous on a 383?
I am planing on building a 383 but am debating about going with SCAT 9000 series or forged. Can the cast crank handle a 150 shot of nitrous?
Old Apr 10, 2003 | 09:53 PM
VETDRMS's Avatar
VETDRMS
Default Re: Nitrous on a 383? (vetteguy216)
I would say Yes, BUT it depends on how much the motor makes off the bottle. If your making 500hp and you throw a 150 shot at it you will be on the edge as far as strength goes. I am using the 9000 series in my 406 and plan to run a 100 shot next winter. RPM kills, and from what I've been told these can handle 600hp, but not much higher than 6500rpm.
:cheers:
Old Apr 11, 2003 | 03:28 PM
jerryjfunk's Avatar
jerryjfunk
Default Re: Nitrous on a 383? (VETDRMS)
I know that SCAT rates them at about 600hp, but I've heard that they are tough enough to go beyond that. Heck, CHP had a stock SBC handling more nitrous than that before it blew up because of their own mistake. I think you'll be fine with a 150hp shot... that's what I plan to do down the road.
Jerry
Old Apr 12, 2003 | 04:55 PM
vetteguy216
It wont be runing any higher than 5500 because I do have a TPI. VETDRMS I am really worried about the HP its the TQ I am afraid of.
Old Apr 12, 2003 | 05:58 PM
J Z06's Avatar
J Z06
My friend has a nitrous system in His 1982 Camaro with a Lingy 383 motor. Cast crank and pink rods/hyper pistons.It's got a Holley 750 on top so it is a little easier to tune the juice.
The n20 doesn't get sprayed much, but when it is in use He has no problems. 11:1 compression also.
Good luck. :cheers:
[Modified by Jay D 90 383, 5:59 PM 4/12/2003]
Old Apr 20, 2003 | 10:53 PM
vette_tweak's Avatar
vette_tweak
Default Re: Nitrous on a 383? (Jay D 90 383)
Jay D 90 , how big of shot is he running? Does he spray for the full 1/4? How much power(dyno'd or calc based on times/weight) is he making with and without the spray?
:cheers:
To Nitrous on a 383?
