whats a stud girdle for?
Old May 1, 2003 | 12:53 AM
vader86's Avatar
vader86
Default whats a stud girdle for?
I was watching Dream Car garage or some show where they are rebuilding an L88, and they pulled off the valve covers and there was something in there that didnt look right and they called it some kind of girdle, but i dont have the slightest idea on what it does and why you need it? :confused:
Old May 1, 2003 | 01:11 AM
SS409 425HP's Avatar
SS409 425HP
Default Re: whats a stud girdle for? (vader86)
Stud girdles (also known as rocker tie bars) are used in some racing engines to reduce stud flex and lock the adjusting nuts in place.
Old May 1, 2003 | 01:29 AM
gkull's Avatar
gkull
Default Re: whats a stud girdle for? (SS409 425HP)
If your rocker studs have more than .040 of deflection due to biggers springs and higher ratio rocker arms you need a stud girdle
Old May 1, 2003 | 03:06 PM
66427-450's Avatar
66427-450
Maintain alignment/geometry...... if you are over-loading the studs.
Old May 3, 2003 | 12:19 AM
Bearcat's Avatar
Bearcat
Default Re: whats a stud girdle for? (gkull)
gkull, how do you know if you have over 40 thousandths deflection?
Old May 10, 2003 | 05:21 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: whats a stud girdle for? (Bearcat)
measure w/ a dial indicator on running engine.
Old May 10, 2003 | 10:31 PM
gkull's Avatar
gkull
Default Re: whats a stud girdle for? (Twin_Turbo)
Bearcat - All your rocker studs should be in alignment before you mount the rocker arms. so you should be able to put a staight edge of metal like a ruler straight down the line.
Then when you install the rocker arms and screw them down to lash. the spring torque will start to bend the studs with deflection. If the studs are moving back and forth from the opening of the valve more than .035-.040 you need a stud girdle.
.040 doesn't sound like much. but just picture where the roller tip is no longer centered on your valve tip. Your guides suffer and in the case of aluminum heads your working the threads and the stud metal will fatigue in time
To whats a stud girdle for?
