Carb ?
Old May 5, 2003 | 01:23 AM
sting73ray's Avatar
sting73ray
Default Carb ?
I have a 73' L48 and want to go with a hi-pro carb but keep the same factory intake? any suggestions?
Old May 5, 2003 | 11:15 AM
66427-450's Avatar
66427-450
Default Re: Carb ? (sting73ray)
i'd do a "performance rebuild" of your Q-jet. it's all you'll ever need for that 350. jetting/different metering rods, etc etc.....
:seeya
[Modified by 66427-450, 11:17 AM 5/5/2003]
Old May 5, 2003 | 02:41 PM
SWCDuke's Avatar
SWCDuke
Default Re: Carb ? (66427-450)
Agree. Your Quadrajet flows 750 CFM at 1.5" Hg. and a "high performance" carb is not going to buy you anything. There are a lot of minor Q-jet mods to improve performance such as modifying the linkage to open the secondaries earlier and maybe some jetting changes along with backdating the ignition map to a pre-emission configuration. Get all the centrifugal in by 2500 with total initial plus centrifugal equal to 36-38. Select a vacuum can with about 16* at 12-15" and run the signal line from a full manifold vacuum source that has manifold vacuum at idle. Since the L-48 only has 8.5:1 CR and was designed for 87 PON fuel, at worse you might have to run mid grade to keep then engine out of low speed detonation, but it will have dramatically better throttle response and low end torque.
Any of the various Rochester Quadrajet books should give you some ideas on how to improve performance. If you really want to wake up the engine at medium to high revs, install an L-82 cam advanced four degrees, but then you'll need a vacuum can with the full 16* advance at 8-10"
Duke
[Modified by SWCDuke, 11:49 AM 5/5/2003]
Old May 9, 2003 | 12:05 AM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
The stock Q-jet is a very good carb but very complicated. I just don't have the time to debug mine. I picked up a Holley 4175 spreadbore for $20 at a swapmeet and plan to give it a try. New 4175's go for ~$300 at Summit or Jegs. Uses electric choke though and best install for that is witha relay off the oil press light sensor. I've gotten tired of all the linkages and tricky parts to adjust on the Q-jet. :(
Old May 11, 2003 | 09:06 PM
redwingvette's Avatar
redwingvette
Default Re: Carb ? (cardo0)
I switched to the Holley 4175. Spreadbore replacement. Some tunnig of the accereator pump cam and discharge nozzles but it works real good. Check out my home page for pics. I did have to get a spacer for the air cleaner to sit right. I changed the manifold after I ran the stock one for a while. Then I kept adding to the mods. :yesnod:
To Carb ?
