400,406 cid - stem holes ?
Please help me with this:
I need an engine for a new project, in this moment I don`t have anything, I want a 400 cid of displacement or 420 from a small block.
I will buy a block from a yunkyard
Can I convert a 350 to 400 ? or will be a better idea to buy a 400
1.- I know that the crank (stroke)will be not a difficult problem (383) but what about the 4.155 inch bore in a 350 ?
2.- If I will buy a 400, I already have the stroke and the bore but what about the siamesed bores (stem holes)in this engine ?
Because I want to install afr 190.
3.- how difficult will be to drill this stem holes on the new heads ?
4.- If I stroke a 350 to 406 I supose that I will not need the stem holes ?
Let me know
Thanks and regards
I'm not sure if you can run 4 inches of stroke in a 350, but with the small bore I don't think it would be worth it.
I am currently building a small block 406 from a 400 block, and I'm using the AFR 195's....In fact they are sitting beside me at the moment.
I had AFR machine the steamholes for me, it was only $55 and they came out good. If you want a picture, I'll upload one shortly.
:cheers:
Well, I figured you'd like the picture, so here you go :)
[Modified by VETDRMS, 8:56 PM 5/18/2003]
Then I will go for a 400 block, and I will ask for the stem holes like you to afr
Thanks and regards
I am doing 391 CID 3.835 stroke in a 4.030 bore. (350 block) Maybe I can get 1 more rebuild out of those cylinders when the time comes.
There is a nice article in february 2003 Chevy High Performance magazine about drilling steam holes (don't forget the gaskets). I can fax it to you if want.
AFR:
yes tell them to add sensor locations. I didn't and I don't have them. I am using 210cc. Part #1053 (L98 plug angle for corvette). They will take about 2 months if not more to make the heads. Maybe next year AFR moves to a bigger facility to make faster head orders. But they are beautiful heads.
very nice CNC ing. The Fel-pro 1205 fits very nice on the port.[Modified by 89 Paul in Cal, 4:35 AM 5/19/2003]
I inquired about have those holes drilled in my Bowtie Block. The machine shop said the deck was too thick. Look down an adjacient water passage to see how deep you would have to drill. Better yet, ask your machine shop. All production, 400 sbc's, have the steam holes.
There are no production Chevy "tall deck" small blocks. The responder above, I forgot to note his forum name, is thinking of medium duty truck big blocks.
RACE ON!!!
1984 Crossfire
Member NHRA
this is from Ed's other post:
why I mentioned it. Ed is in Mexico and I am Mexican also. I haven't been down south in a few years, but am familiar with how things are down there :D
Just was trying to give a heads up on possible block differences. :cheers:
Just trying to help. Good luck, and...
RACE ON
1984 Crossfire
Member NHRA
