Piston rock, how much is there on average?
Old Jun 11, 2003 | 11:16 PM
inqbus383's Avatar
inqbus383
Default Re: Piston rock, how much is there on average? (CFI-EFI)
My 405 has a deck height of .027, and a .39 head gasket. .066 quench, and it works great. No detonation problems.
Old Jun 12, 2003 | 03:28 PM
norvalwilhelm's Avatar
norvalwilhelm
In my case I am running an o ringed block which is stainless wire sticking .008 out the the deck. I need to run a solid copper gasket and if I ran a .020 gasket it would bother me that the O ring is bitting too deeply into the gasket. Also I hang around a very knowledgable Cancar guy that always decks the block to Zero.
Old Jun 12, 2003 | 09:11 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Piston rock, how much is there on average? (inqbus383)
The lack of a tight quench area will not make it knock. After about .060" of piston to head clearence, you lose the benefits of the quench area. That does NOT mean that is has to knock. If you're happy with your .066" clearence, I'm happy with your clearence, too. Good luck, and...
RACE ON!!!
1984 Crossfire
Member NHRA
Old Jun 12, 2003 | 09:35 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
the closer to the head the piston is the less fuel mixture is trapped there and you make more power. the fuel trapped between the head and the piston does not burn completely and you will lose power. on drag race engines i have the pistons almost kiss the heads so all the fuel is burned completely. :chevy
Old Jun 13, 2003 | 08:19 PM
arnold's Avatar
arnold
Default Re: Piston rock, how much is there on average? (ld85)
The reason I ask is for the quench, I measured the top of the piston at several points, using depth micrometers, and took the hi and low and averaged them.
The "rock was @ .0035" so I am considering a close to zero deck so I can use .039 gasket this go around instead of .022 in the hole and .021 copper gaskets. This would keep me in the .040 range for quench.
For me, this is too vague and aggravating. I put masking/scotch tape on piston in ring land area, and if clearance is great enuf, tape on skirt. When installed that piston is THERE. There is no rock, nada. Now you can get accurate deck dimensions, and no jerking around. :)
Old Jun 13, 2003 | 08:58 PM
66427-450's Avatar
66427-450
Default Re: Piston rock, how much is there on average? (arnold)
never heard of the tape thing.....
i just checked my build sheet:
the 468 replacement engine i just built has SRP 4032 hi silicone # 142987 pistons, i just measured the piston dia, then honed the bore to get .0045 clearance, i fit each piston to its bore.
seems simple enough to me, never measured, and really don't care about, "rock"
quench: - .003 deck, .039 gasket = .036 quench (thats with scat H-beams, and merlin IC heads)
Old Jun 13, 2003 | 10:20 PM
LD85's Avatar
LD85
Default Re: Piston rock, how much is there on average? (66427-450)
Well my quench is going to be .044", Decked at +.005 with a .039" Felpro Gasket.
I am not too concerned about being .004" over "ideal".
Old Jun 15, 2003 | 01:13 PM
CFI-EFI's Avatar
CFI-EFI
Who ever said, .040 is ideal, either misspoke or just plain doesn't know. Tighter, is better. Chevrolet has determined that .035" to .040" is the minimum "safe" clearence. Some have built engines with less and survived. Part of the question is, how much can you afford to gamble? The benefits of quench slowly deterorate to where they are mimimal at .060" and greater. At .044" you are at the right end of the range. You'll be fine. Good luck, and...
RACE ON!!!
1984 Crossfire
Member NHRA
Old Jun 15, 2003 | 07:43 PM
LD85's Avatar
LD85
http://chevyhiperformance.com/techarticles/94138/
For decades, sharp engine builders have known about “quench” or “squish.” These terms refer to the area in a wedge-shaped chamber designed to create turbulence in the chamber as the piston approaches top dead center (TDC). This squish effect can also occur in other types of chambers as well. We will limit our discussion in this story to small-block Chevys, but the basic facts relate to all wedge-shaped combustion chambers.
The quench area is the tight area between the flat portion of the piston and the flat portion of the combustion chamber in a typical wedge-style chamber. As the piston reaches TDC and the mixture begins to burn, the air and fuel located between the piston and the head is squeezed or squished out into the dished portion of the combustion chamber. Think of the turbulence that occurs when you smash a tomato with a large mallet and you get the idea. With a flat-top piston, this squish area can be very tight. This is also the tightest clearance between the piston and the cylinder head. Since mechanical contact between the piston and the head is not advisable, most production engines rely on a piston-to-head clearance of 0.060-inch or more in this area.
Unfortunately, this is not an ideal piston-to-head clearance for optimal squish. But because of production tolerances, factory engines usually fall on the larger side of the clearance for obvious reasons. But when it comes to optimizing a performance engine for more torque and horsepower, this is an area where a knowledgeable engine builder can squeeze out a little more power.
The Squish Effect
Since wedge-style combustion chambers rely on the squish or quench area to create turbulence in the combustion chamber, an intriguing effect occurs in the combustion process. To better understand this process, imagine that the intake valve opens and a rush of air mixed with fuel enters the combustion chamber area. The piston comes screaming up toward TDC at 5,000 rpm (almost 3,000 feet per minute) as the intake valve closes. As the piston reaches TDC, a virtual hurricane of fuel and air is squished out into the chamber from this tight area between the piston and the head. While this turbulence sounds bad, the opposite is true. This turbulence has the effect of more thoroughly mixing the air and fuel into a much more homogenous mixture that tends to burn much more quickly and efficiently.
One way to produce maximum power from an engine is to use the least amount of fuel necessary to create maximum power while attempting to burn all of it. Given this, if you can evenly mix the air and fuel into a homogenous mixture with an extremely fine mist of fuel, you will make outstanding power.
Unfortunately, the opposite is also true—varying pockets of lean and rich mixtures within the cylinder when the spark plug fires will cost power and the combustion process will not be as smooth. Excessively lean or rich pockets within the chamber directly affect the rate of combustion and the amount of pressure applied to the piston. Rich mixtures tend to burn slower, while lean mixtures generally burn at a faster rate than a “proper” air-fuel mixture. If modifications to the chamber or piston affect these rates, the ignition timing will also need to be changed to optimize power.
What is the proper air/fuel mixture? In the last few years, the answer has been changing as the area between the combustion chamber and the top of the piston becomes more efficient. For example, the classic air/fuel ratio has always been 12.5:1, meaning 12.5 parts of air for every one part of fuel. But many race and properly designed street engines can make best power with air/fuel ratios now approaching 12.8 to 13:1.
So now let’s introduce a tighter quench space into this equation. All of the respected engine builders who we’ve talked to are firm believers in minimizing the quench clearance. According to Ken Duttweiler, the tightest quench he recommends is around 0.050-inch. He has built engines with far tighter clearances than this, but much of this depends on the piston-to-wall clearance. All pistons tend to rock slightly as they transition through TDC and this rocking motion reduces the piston-to-head clearance. Smaller-diameter pistons with tight piston-to-wall clearances don’t rock nearly as much in the cylinder bore compared to larger-bore pistons with wider piston-to-wall clearances.
Since piston clearance plays such a big part in piston-to-head clearance, it is possible to run a piston-to-head clearance tighter than 0.040-inch if you feel brave. Noted horsepower hero John Lingenfelter says that clearances of 0.037 to 0.040 inch are possible, but you must know what you’re doing. The late Smokey Yunick also recommended a quench clearance of 0.040 inch as a safe but critical clearance.
Advantages
So what are the benefits of all this squishing and quenching? The benefits are small, but >> often important. Pump-gas engines that run on the ragged edge of detonation, for example, can greatly benefit from a tighter piston-to-head clearance to reduce rattle. That sounds contradictory since increasing compression should lead to increased detonation. All the engine builders we spoke to mentioned that tightening the quench (reducing the piston-to-head clearance) to get it under 0.050 inch will increase the static-compression ratio, but this tighter clearance also creates a more powerful squish effect. This additional turbulence creates a more homogenous “soup” in the chamber, reducing the harmful effects of lean air/fuel ratio pockets. With all other variables being equal, this contributes to creating an engine that is less prone to detonation.
We tried this on a recent dyno flog of a 383ci small-block. To keep the compression at around 9.5:1, we used a set of 0.050-inch head gaskets that created a wide piston-to-head clearance of around 0.060 inch. CHP engine flogger Ed Taylor swapped in a set of 0.040-inch Fel-Pro head gaskets and then tested the engine again. We witnessed only a marginal gain of around 2 to 3 hp (less than 1 percent), but it’s doubtful that the marginal increase in compression was responsible. Clearly, tightening quench with a thinner gasket had something to do with the increase in power. Tightening the quench area often results in the reduction of ignition timing requirements. This can then lead to a reduction in negative work (the cylinder pressure rising while the piston is still approaching TDC). This often is evidenced by a gain in low- and mid-range torque.
There is plenty of discussion about the net effect of squish and quench. While it’s doubtful that this will ever amount to more than a few horsepower in any street application, it does offer some distinct advantages when it comes to increased engine efficiency, better fuel mileage, and driveability. If you’ve ever wondered why certain engines run better than others, this could be one reason why.
Old Jun 15, 2003 | 08:06 PM
CFI-EFI's Avatar
CFI-EFI
I couldn't have said it better myself.
As an offshoot, the less total spark advance that produces maximum HP in a given engine, the more efficient that engine is. Many factors go into combustion efficiency, but with so many constants, such as engine basic design (sbc for one example) it pays to pay attention to the quench. That is ONE thing, we as builders, can control. Good luck, and...
RACE ON!!!
1984 Crossfire
Member NHRA
Old Jun 15, 2003 | 08:14 PM
arnold's Avatar
arnold
I'm not sure if I understand you and the referenced article. But to play safe, and in the interest of making sure others that read this thread aren't confused, quench does not need flat surfaces to be affective, so also applies to hemipherical chambers as well.
Old Jun 15, 2003 | 09:24 PM
LD85's Avatar
LD85
This artical is a quote form the link posted above it, out of
Chevy Hi Performance Mag.
Old Dec 14, 2025 | 07:49 AM
  #33
3R1$C's Avatar
3R1$C
from the LS1 Tech forum: Stock pistons cold rock about .020 ish as in if one side is pushed sideways it may go .010 out of the hole and then .010 in the hole when rocked the other way. Forged pistons have generally more rock when cold. Some of the wiseco and Diamond LS1 specific stuff is still only like .020-.025 where as some traditional forgings and skirts can be much more like .030-.040 even so it all depends. When hot these all rock much less.
Measured 0.7mm (0.030") on my boosted LS7 build with Diamond pistons.
