Are all 350 small blocks created equal???
Old Jun 16, 2003 | 11:03 PM
NUckINg FuTS's Avatar
NUckINg FuTS
Default Are all 350 small blocks created equal???
Ok, I'm looking into buying a 70's 350 block with 4-bolt mains for my upcoming project. Basically, my question is will it work in my car?? Will all the part from my current engine swap into this block?? I have an '86 corvette with an L-98 engine, non roller 2 piece rear main. Oh yeah the casting number for the block I'm looking at is "3970010". Thanks :cheers:
Old Jun 16, 2003 | 11:10 PM
danno85's Avatar
danno85
Default Re: Are all 350 small blocks created equal??? (NUckINg FuTS)
About the only difference between that older block and your 86 is that
the dipstick is on the driver's side on the earlier blocks and on the passenger
side on your later 2-piece rear seal block. I put an early left hand dipstick
block in my 85 and since I've got long tube headers it's not a problem.
You'll need an oil pan for left dipstick also.
Dan
Old Jun 16, 2003 | 11:35 PM
JUAN J SANCHEZ's Avatar
JUAN J SANCHEZ
Default Re: Are all 350 small blocks created equal??? (danno85)
Beware, not all 3970010 blocks are 4 bolt main. Yes the major diff is the dipstick side ,but everything else is the same.Good luck!
Old Jun 17, 2003 | 08:29 AM
NUckINg FuTS
Default Re: Are all 350 small blocks created equal??? (JUAN J SANCHEZ)
Thanks for the replies!
Danno85,
Would I be able to buy an oil pan that will fit this block and also retain a right side dipstick????
I have pics of this particular block and it defenitely has 4 bolt mains :yesnod:
Old Jun 17, 2003 | 09:15 AM
danno85's Avatar
danno85
Danno85,
The problem is going to be that the early block you're looking at doesn't have
the "pad" on the oil pan rail on the right side pan rail for the dipstick. If it did, you could drill the hole for the dipstick on the right (it just goes through the pan
rail maybe a half inch), plug the dipstick hole on the left, and use a right hand
dipstick oil pan.
Old Jun 17, 2003 | 10:38 AM
LD85's Avatar
LD85
I have a brand new driver side dip stick Z-28 oil pan I will let go reel cheap!
Old Jun 17, 2003 | 03:27 PM
WashingtonRacer's Avatar
WashingtonRacer
Default Re: Are all 350 small blocks created equal??? (ld85)
I believe Miloden makes a pan that has the protrusion for the drivers side dip stick. but then has it's own protrusion on the passenger side on the pan it's self for a dip stick. So in short. It solves that problem, if is was even a problem to begin with. Dimensionally almost all the blocks are going to be the same on the outside. The only other thing to look at is if it has provisions for both style starters, "staggered and straight style". I have a 4 bolt block 350 bored 40 over just sitting in my garage collecting dust. Also have a crank and rods :).. need it out of there!!
To Are all 350 small blocks created equal???
