Forced Induction/Nitrous and Forged Pistons
The valvetrain on both sides of the engine were pretty quite, with the exception of the tale-tell ticking of the solid lifters. The bottom end was pretty quite as well, although the "slap" was more noticeable. I could definitely tell it was coming from the rear of the engine, actually it sounded like it was coming from the torque converter. I stopped then engine and took a closer look at the converter, and realized that the converter bolts that attach it to the flexplate were slightly loose.
When I initially assembeled everything, I used red Loctite, as well as star lock-washers on the bolts, but they managed to loosen slightly. They were still tight, at least 40-50 ft lbs. The problem is that the converter is tapped for 10mm bolts, but the holes in the flexplate are 7/16", so there's a little slop. What was happening is that during warm up when the idle is still a little rough, the bolts were hitting the insides of the bores in the flexplate. When the engine warmed up and the idle smoothed out, it was no longer a problem. I pulled the bolts out, cleaned them, and reapplied Loctite and retorqued them and the noise was gone.
Since I was under there, I went ahead and drained the oil and pulled the pan anyway, just to give everything a good look since. Everything looked as good as new.
