Nitrous on this engine?
Old Jul 2, 2003 | 03:14 PM
Glutamine83's Avatar
Glutamine83
Default Nitrous on this engine?
hi everyone
is it safe to run a small nitrous system on this engine?
355 ci
hyper-eutectic flat-top pistons
bigger cam
2.02/1.60 heads 72 cc
over 9.5:1 compression????
see sig for details
and how big of a nitrous system can I safely run?
Old Jul 2, 2003 | 03:26 PM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Default Re: Nitrous on this engine? (Glutamine83)
NOS on hyper pistons is a little risky, if you run into detonation you can easily break a piston. You would probably be safe with a small shot 100-125 and make sure you run good gas and take 2-4 degrees of timing out. That is probably over safe, but better than that sorry.
I know of a few guys that run hyper pistons and NOS, they are just careful
Old Jul 2, 2003 | 03:54 PM
Glutamine83
Default Re: Nitrous on this engine? (69 N.O.X. RATT)
one of the big considerations when building the engine was whether I was doing nitrous or not, but I didn't anticipate it being an option, so I didn't bother with the extra expense of forged pistons
if I did go with a nitrous shot, it would be even smaller than 125, maybe under 100
Old Jul 2, 2003 | 04:49 PM
MasterDave's Avatar
MasterDave
Moderator
Stick with a 100 shot max and you'll be fine. Just for safety sake get a better fuel pump, (like Edl) that's it. :thumbs:
To Nitrous on this engine?
