Collector Muffler? How can this be done?
Old Jul 22, 2003 | 07:18 PM
VETDRMS's Avatar
VETDRMS
Default Collector Muffler? How can this be done?
I think my current 2.25" exhaust system will be somewhat restrictive, and I was thinking of replacing the whole system with some type of muffler that can be bolted directly after the collector, and then using a 3" turnout to exit under the front of the door behind the front tire. Here's an idea:
Small section of 3" tube to connect collector to Dynomax Bullet, 3" mandrel bent tubing exiting at 45 degree angle at front of door before transmission crossmember with the end cut at an angle horrizontal to the frame rail.
This would make for a elongated oval exit that "I" think would look pretty good, and sound good as well. It would weigh less than the full system, and be a LOT less restrictive.
Ideas/inputs welcome,
Thanks! :cheers:
Travis
[Modified by VETDRMS, 5:19 PM 7/22/2003]
Old Jul 23, 2003 | 06:21 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Default Re: Collector Muffler? How can this be done? (VETDRMS)
Gotcha covered!
For my 68' Camaro I seal brazed on some Stainless steel 3" collector ends I bought from Summit $30 some 10 years ago onto Borla silver bullit muffs.
After the headers, I put on the cutouts, then the muffs and ran 2.5" pipe out to the stock exit on both sides.
It sounds good.......... :D
Here is a pic of the parts
Old Jul 23, 2003 | 11:37 AM
VETDRMS's Avatar
VETDRMS
Default Re: Collector Muffler? How can this be done? (ALLTHROTTLE&NOBOTTLE)
Thanks! :cheers:
I am going to get the motor installed in the coming weeks, then its time to dig into that project! Hopefully I'll have it to the track by mid august. :yesnod: :cheers:
To Collector Muffler? How can this be done?
