Anyone useing a MAIN STUD GIRDLE(pics)
Old Jul 23, 2003 | 11:36 PM
Ray383's Avatar
Ray383
Default Anyone useing a MAIN STUD GIRDLE(pics)
Found it on Ebay. I've been looking for something like this for about a year. Does anyone have any thoughts on it? Anyone using one?
Here is the description:
#####This girdle works to stabilize the main caps by spreading the load evenly over all the main caps, making the block nearly bullet proof!! Hawks Racing steel main stud girdles are machined from billet steel to our specs. Flat surfaces are finished using CNC machine center for accuracy and smoothness. The girdles are zinc anodized for attractive appearance and rust resistance. This kit includes 5140 high strength studs, hardware and instructions for complete installation package!!
Old Jul 28, 2003 | 09:04 AM
ZD75blue's Avatar
ZD75blue
Default Re: Anyone useing a MAIN STUD GIRDLE(pics) (Ray383)
TTT :eek:
Old Jul 28, 2003 | 09:40 AM
gkull's Avatar
gkull
I seen them before on all out race motors. But not very often. If strength is what your after.
Stage one is ARP Crank stud kit on a good 4 bolt main block. Good for up to 600 hp
Stage II is something like Milodon super main caps and ARP Stud kit.
Stage III is block bored and tapped for Splayed main caps.
Stage IV is aftermarket blocks.
Partially filled water jackets is also a strengthening idea for any of the above combos. Since stage II & III are used every day for Small block chevy's that make as much as 700 hp in racing I'm not even sure what they claim with a girdle.
Old Jul 28, 2003 | 04:45 PM
bill mcdonald's Avatar
bill mcdonald
I was looking for one of those back in 1998 when I built my engine.
I was told there is none. cool that someone finally did it.
I got the idea after reading about them being used on mustangs. I think the ford 5.0's only have 2 bolt mains or something like that.
Old Jul 29, 2003 | 11:56 PM
Ray383's Avatar
Ray383
Default Re: Anyone useing a MAIN STUD GIRDLE(pics) (bill mcdonald)
I'm trying to find out if it would be helpful for the engine I'm building for my 85. Here are the details on the engine so far:
383
4 bolt non-roller block
bored .030 over and clearanced for 3.75 stroke
Eagle forged rotational assembly
5.7 h-beam 4340 rods
3.75 stroke 4340 crank
pistons are still a ??
AFR 190 heads
LPE 219 cam, cam button, and crane retro rollers
crane 1.6 roller rockers
SuperRam plumbed w/ direct port Nos (100-300 shot)
52mm TB
LPE 1 3/4 primary long tubes
It should put down some good #'s. My guess is +/- 400hp & 500ft/lbs at the fw off the bottle. I'm going the start with a 100 shot and work myself up to the 250-300 range as I get the tune dialed in. I haven't picked out pistons because I'm not sure what compression I want to run. I'm thinking 10.5-11.
I'm not sure that I will ever run more than a 150 shot, but I would like the be able to if I want.
Would this Gridle Help? Any thoughts or comments on the engine combo are welcome. Any recomendation on pistons? The heads are 68cc.
Ray
Old Jul 30, 2003 | 11:44 AM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
my question about those girdles would be,"how does it effect oil windage in the engine" because it looks like it could cause oil drain back problems. :chevy
Old Jul 30, 2003 | 03:02 PM
gkull's Avatar
gkull
I would get flat top SRP (JE) pistons with 6 inch rods. Get the internally balanced crank. depending on the deck height figure out the head gasket thickness.
I would forget the girdle and have your block converted to a four bolt main if it's not already. Your stroker crank and rods can be a lifetime investment. So that's where I put my money.
Out of all the blown motors I've looked closely at over the years. Only one time have I ever seen block failure as the cause. It's usually broken crank shafts or rods. I've also experience piston failure and seen holes and broken pistons from detonation and severe lean out.
To Anyone useing a MAIN STUD GIRDLE(pics)
