cam grinding company?
Old Aug 13, 2003 | 06:23 PM
zrracer's Avatar
zrracer
St. Jude Donor '11, '14
Default cam grinding company?
I am looking for a company that can grind a custom cam. I remember that their was one in Missippi or around their ?
Thanks,
Robin
:cheers:
Old Aug 13, 2003 | 06:54 PM
danno85's Avatar
danno85
Default Re: cam grinding company? (zrracer)
There are several that can.
Comp Cams is in Memphis.
Dan
Old Aug 13, 2003 | 06:59 PM
zrracer's Avatar
zrracer
Default Re: cam grinding company? (danno85)
Thanks Dan.
Old Aug 14, 2003 | 10:02 AM
mountainmotor's Avatar
mountainmotor
Are you looking for this Company ?
Cam Motion
2092 Dallas Drive
Baton Rouge, LA 70806
Phone: +1 (225) 926-6110
Fax: +1 (225) 923-2101
Sales: sales@cammotion.com
Others would be Reed Cams , Crower and Schneider .
Old Aug 14, 2003 | 11:01 AM
zrracer's Avatar
zrracer
Default Re: cam grinding company? (mountainmotor)
Old Aug 14, 2003 | 11:34 AM
gkull's Avatar
gkull
I hate Comp Cams! :mad They advertise and promise things that they don't even sell.
But other than that custom cams is a misnomer unless you want to pay $1200-1500 for the tooling to actually make a cam to your specs.
When it comes right down to it with all the companies they have pages of lobe profiles. Each lobe has a ramp speed or type, total lift, and duration at .050 or some other spec.
So custom cam really means finding the manufacturer that has the speed, lift, and duration to fit your needs for each lobe. Crane cams actually produces the blanks for many of the other manufacturers.
The blanks have such large lobes that they can be ground to lobe sepparation of 104- 118 degrees. So you can name your LSA.
Old Aug 14, 2003 | 12:04 PM
zrracer's Avatar
zrracer
Default Re: cam grinding company? (gkull)
gkull,
Who would you recomend??
Thks
Robin
:cheers:
Old Aug 14, 2003 | 02:13 PM
gkull's Avatar
gkull
First of all what are you trying to do. I only use sollid roller cams because they don't have the rpm limitation that H-Rollers do. Most people are better off with H-rollers.
I only buy billet steel cams and with the sleeved gear you can use your common distributer gear.
If you told me the specs you need or what your expecting I could advise you better. I called about 5 manufacturers to get my last cam. Very few make extreme ramp profiles in relatively low durations. Extreme ramps get the most power, but at the cost of short life for the valve train.
Go to the Crane web page and they have a nice selection of off the shelf roller cams. Off the shelf are $150 - $200 less than "custom" grinds
Old Aug 14, 2003 | 03:02 PM
zrracer's Avatar
zrracer
The plan is for a roller. I have to use the stock intake exc. on a 90 L-98. It just runs out of air. I am going to flow the intake parts this week so we have a better idea of what to do.
Robin
Old Aug 15, 2003 | 05:29 PM
LD85's Avatar
LD85
You are correct, they did my custom cam and od awesome work!
Bullet Racing Cams, LLC
8785 Old Craft Rd
Olive Branch, MS 38654
(662)893-5670, Fax (662)893-6056
John D. Partridge
http://www.bulletcams.com
[Modified by ld85, 5:31 PM 8/15/2003]
Old Aug 15, 2003 | 08:45 PM
redvetracr's Avatar
redvetracr
zr, Call Lunati/Holley in Memphis, tell them you want to talk to "Harold Brookshire" aka the camshaft GENIUS. Harold was/is Ultradyne but ran into some "tax" problems and had to go to Lunati/Holley. You won`t be sorry!!
...redvetracr
Old Aug 15, 2003 | 09:00 PM
JoeC427's Avatar
JoeC427
Quote: Are you looking for this Company ?
Cam Motion
2092 Dallas Drive
:iagree:
They provide great customer service, and I am very pleased with the custom grind camshaft they spec'd in for my 427.
Old Aug 16, 2003 | 08:36 AM
zrracer's Avatar
zrracer
Default Re: cam grinding company? (striker427)
Thanks guys !
Robin
:cheers:
Old Aug 17, 2003 | 02:04 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Don't see any flat-hyd. cams in the short duration range of 265-275 with tight lobe separtion angles of 104-107. What I'm asking is will Crane or Isky grind one for relatively few bucks? gkull have you seen this done at close to off the shelf price? :confused:
Old Aug 17, 2003 | 02:37 PM
Les's Avatar
Les
Default Re: cam grinding company? (redvetracr)
...redvetracr
Wow, it's good to know he's surfaced somewhere- Lunati/Holley made a very good move picking him up! I'll be watching for changes in their cam line now.
I'll second what redvetracr says :thumbs:
To cam grinding company?
