AFR Heads Purchased!
Old Aug 14, 2003 | 12:33 AM
No Go's Avatar
No Go
Default AFR Heads Purchased!
Just ordered set of 1050 210cc heads for my old style 407 small block chevy.
Plan to use them with a small solid flat tappet cam to make easy tuning with my Holley EFI. I think the engine will still make good power...much more so than my 041 castings...:)
They claim 6 weeks...I'm not holding my breath...:(
Old Aug 14, 2003 | 02:13 AM
VETDRMS's Avatar
VETDRMS
Default Re: AFR Heads Purchased! (No Go)
You may see your heads earlier than you think! When I orded mine they said 8 weeks. At around 5 weeks after the order I called to see how it was looking, they told me still another 3 weeks. Within a couple days the UPS man showed up with the heads. Apparently they didn't even know they were on the way... :confused:
As far as how they run.... my 407 is done and about to be installed this weekend, so i'll be sure to report.
One note, and this could of just been a fluke....but. I had mine vacuum tested right out of the box at least half of the valves failed. :(
The seats (and valves) had a non-concentric cut (old stones?). I had the seats fixed and the valves touched up and they all seal perfect. Also, I had a little extra work done in the bowl and exhaust port as my machinist felt there was a little room for improvement. (yes, i trust him...for good reason).
So, just check the seats for a little piece of mind, its easy enough. Its a good idea to tear down any assembled head...people make mistakes.
Good luck, hopefully mine will run as planned. :reddevil
Old Aug 15, 2003 | 05:29 PM
bill mcdonald's Avatar
bill mcdonald
took me 2 months with constant bitching back in 98.
[Modified by bill mcdonald, 2:29 PM 8/15/2003]
Old Aug 15, 2003 | 05:31 PM
LD85's Avatar
LD85
Default Re: AFR Heads Purchased! (bill mcdonald)
:lurk:
Old Aug 15, 2003 | 08:23 PM
No Go's Avatar
No Go
Default Re: AFR Heads Purchased! (VETDRMS)
That is a good point.
I had planned to have them looked over and cced and flowed by my local shop. Give me some hard and fast numbers to play with. Doing the vacuum test is one that had not crossed my mind, but will do.
My first purchase of aftermarket heads...like I said, it ought to make the 400 air pretty good. Hoping for a 7000 rpm shift point...with my Tremec.
Can't wait...
Old Aug 15, 2003 | 11:40 PM
71coupe's Avatar
71coupe
You will like the change to aluminum heads :yesnod:
My detonation problems disappered after I installed my Darts
(I almost bought AFR's - had them down to 1225.00 out the door, but got a better deal on Dart Pro 1's)
:cheers:
Old Aug 26, 2003 | 10:50 PM
DGT76's Avatar
DGT76
St. Jude Donor '03 & '05
:cool: Hope to order mine soon!!
Old Aug 27, 2003 | 03:31 PM
LD85's Avatar
LD85
Default Re: AFR Heads Purchased! (DGT76)
Let us know how long the delivery takes.
Old Aug 28, 2003 | 07:17 AM
No Go's Avatar
No Go
Default Re: AFR Heads Purchased! (ld85)
Updated delivery date...is 17 Sep.
That makes a hair short of 5 weeks.
Old Sep 1, 2003 | 09:13 PM
8T1-7T9 BIONIC VETTE's Avatar
I have AFR 210 heads going on my 427 ci small block......I waited about 8 weeks for delivery.
Please post how they perform.....and if you like or dislike the performance. Mine will be installed in about a week.
To AFR Heads Purchased!
