I'm currently running a Comp XR-288HR Hydraulic Roller Cam.
Specs:
236/242 @ .050
.555I/.540E
110LS,106CL
CR is 10.4:1
AFR 195 Heads
Victor Jr Intake
I think I'm at or near the 500 mark. It sure is one heck of a ride. :reddevil
I am also running a 4000rpm stall.
I am looking forward to getting to the track and seeing how it will run. There are a couple other 406's on the forum that are nearly identical and they are in the low 11's, although they are in C4's as well.
ld85 The cam is fairly docile. It idles at 800rpm (albiet with a lope). It only pulls ~9" vacuum at this idle however. Part throttle driveability is great, and its very responsive. It pulls ferociously on the top end and so far it has been great. I also don't have any issues with my brakes or headlights. I'm hoping i'll be able to make some smoke videos this coming weekend... :reddevil
I have a Comp cams XR custom lobe Hydraulic roller cam, pushrods, and lifters for sale. I need the cam card but it's something like 242/248 @ .050 110 .555/.568 with 1.5's
It's their recommended cam for motors like VETDRMS or street strip motors in the 406-427 ci range.
I just don't want to have anymore to do with comp cams and I have never run a h-roller cam before
QuickVet - when you get into small blocks over 400 ci it's surprizing how large of cams that you can run and still maintain streetability. I have run as small as 232 intake duration of roller cams and now 240 intake. I don't think that you would have issues until @250 intake at .050
What you really need to think out with the help of some Desk top dyno program is where do you want your max hp and tq to occur. IMO the best idea is to have max hp occur 600 - 800 rpm below the intended red line. That way you still have power, but its tappering off as you approach red line.
The reason that I'm selling the comp cams is it's the second time that they have promised a small base circle cam and both of them have been 1.050 inches.
It's okay to use that size cam with large H-beam rods in 3.750 stroke motors. But I'm building a 4 inch stroke and we had to grind all the rods and rod bolts to clear this H-roller cam. We got it to clear after lots of grinding. I'm just going to use solid rollers and an off the shelf Crane solid roller cam. Which really are .900 inch base circles.
Mines a Comp XE-284 hydraulic with 240/246 @ .050 running with 10.0:1.Idles at 650 with the fenders shaking,but will rip to 6500 easy.Most build ups like mine seem to be fairly close to 500hp/500lbs,but I've not dynoed to confirm.
I have on occasion had power brake problems,but it is not consistant. I wouldn't go bigger for a street driver though.
Well, Air Flow Research has some of the best flowing heads around. If you look on thier website ( www.airflowresearch.com ), they have dyno's posted. For thier 406 cu in engine, they have a 10.3 compression with thier 210 heads and a Lunati Hyd. Roller Cam 232°/242°
0560-.570 lift W/ 1.6 Rockers. Very impressive torque numbers. 550 HP. 540 # of torque @ 5000 RPM. 463# at 2500.
