O/T Torque Wrench Recommendation?
Old Nov 19, 2003 | 04:27 PM
66427-450's Avatar
66427-450
Default O/T Torque Wrench Recommendation?
Time to upgrade, my old 60's vintage beam-type Craftsman needs a rest. I've been borrowing "click" wrenches for a few years now.......
What brand/model is the hot setup, I figured some of you pro, or semi-pro, guys would have a strong preference.
Thanks -
Old Nov 19, 2003 | 04:31 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Default Re: O/T Torque Wrench Recommendation? (66427-450)
I got a nice one from Sears. It is a 3/8 inch drive and about 1.5 feet long. I forget the number and all it was, but am really pleased with the purchase. It clicks and has the rotating handle for the torque settings.
Old Nov 19, 2003 | 04:37 PM
scorp508's Avatar
scorp508
Default Re: O/T Torque Wrench Recommendation? (Sigforty)
I use a Snap-On 1/2" drive click type for the heavier stuff 75-200 ft/lb and then a Snap-On 3/8" drive bending type for the smaller 10-75 ft/lb stuff.
Old Nov 20, 2003 | 04:15 AM
black bart's Avatar
black bart
Default Re: O/T Torque Wrench Recommendation? (scorp508)
I have been using a clicker for several years but just bought a new sears torque sensor meter it is like three in one because it reads from 0 -150 since you put it on a bar of your choice I use a really long breaker bar for higher torque it makes it far easier than torqueing to 100 with a short bar.
To check this one out at Sears.com type part #44598 in the search
The digital numbers are large and it also has a audible sound that beeps as you get close to the set torque and gets faster as you get closer. Sound can be turned on or off it has a peak torque hold function plus target torque. Check it out pretty neat made in Germany one year warrantee
Old Nov 20, 2003 | 09:32 PM
Daffy2's Avatar
Daffy2
I bought a low cost 0-50 clicker and found the thing to be so P-Poor that I just used my companys equipment to set it as a single use wrench for plugs in aluminum heads. Learned my lesson (again, darn it) don't cheap out on tools. Back to Snap-On.
Daffy
Old Nov 20, 2003 | 11:40 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
:nonod: Nothing wrong with a good beam wrench. My understanding is they only go out of calibration if the beam gets bent. And that pivot handle ensures the torque is applied at same/correct length with every turn. Cheap too, about $15. Ya know sometimes I would like to know what torque is needed to break free a nut or bolt – though I realize break-free torque is usually much less than setting torque. The wider/longer scale wrenches are easier to read. Just wish I could find a cheap ¼” beam wrench for my carbs – no not $100 Snap-On or NAPA.
But presently I do use my Harbor Frieght click style. Many because I bought them long ago and able to calibrate them at work. If my toolbox had more room I would like to add some beam wrenches. :lol:
Old Nov 21, 2003 | 09:29 PM
Chance's Avatar
Chance
From: I was a young troubadour when I rode in on a song, and I'll be an old troubadour when I'm gone.
St. Jude Donor '08
I use to do calibration checks on torque wrenchs for the company at which I work. Mostly Proto and Snap-on. The bending beam wrench were consistantly more accurate than the click type.
D'OH Log on to my son's account! :nonod:
[Modified by X-FireChance, 8:31 PM 11/21/2003]
Old Nov 21, 2003 | 10:00 PM
No Go's Avatar
No Go
Sears!
Old Dec 2, 2003 | 11:35 AM
ZD75blue's Avatar
ZD75blue
Default Re: O/T Torque Wrench Recommendation? (No Go)
I've got a 1/2 inch beam wrench...
Just get some adapters if ya need 3/8ths :iagree:
Old Dec 2, 2003 | 04:20 PM
USAsOnlyWay's Avatar
USAsOnlyWay
Default Re: O/T Torque Wrench Recommendation? (cardo0)
I also just picked up a click style Harbor Freight one. It isn't a Craftsman, but it torqued several bolts up to 95ft/lbs this weekend when I did a tranny swap! :thumbs:
To O/T Torque Wrench Recommendation?
