400 small block 153 tooth flywheel
Old Dec 3, 2003 | 06:00 PM
MikeM's Avatar
MikeM
Default 400 small block 153 tooth flywheel
I need to get one of these. Where's the best place? It's for standard shift and 10-10- 1/2 " clutch. I have a flex plate with the external weight added but I don't know if you can successfully do this with a stick flywheel. I also know there is a weight you can add between the flywheel and the crank. Don't know how it works. Looks like it would drive the flywheel back through the front pump.
Mike
Old Dec 3, 2003 | 07:52 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: 400 small block 153 tooth flywheel (MikeM)
It is going to have to be an aftermarket item. Chevy never used the small flywheel/flexplate on the 400. Therefore, there is no stock, unbalanced 'wheel, available. Check out the topic, "Starter on 400 block", by Jack 71. I have posted quite a bit in there on the subjact. You might check your block for three starter mounting holes. If you don't, already, you'll understand what I mean, after perusing that thread. Good luck, and...
RACE ON!!!
Old Dec 3, 2003 | 08:19 PM
LD85's Avatar
LD85
http://www.paceparts.com/store.asp
I have a 4+3 1985, 153 tooth flywheel with a 400 std. crank,, using the balancing plate.
My crank is internally balanced and the flywheel & clutch assembly is externally balanced,,,, or you can buy a flywheel for an internaly balanced engine for @ $170 if I remember correctly.
EDIT,, they changed their website so you might want to give them a call.
[Modified by ld85, 8:30 PM 12/3/2003]
Old Dec 3, 2003 | 09:10 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: 400 small block 153 tooth flywheel (ld85)
:lurk:
Old Dec 5, 2003 | 05:57 AM
MikeM's Avatar
MikeM
Larry:
Thanks.
Mike
Old Dec 5, 2003 | 11:21 PM
Lionsden's Avatar
Lionsden
Default Re: 400 small block 153 tooth flywheel (CFI-EFI)
:lurk:
:iagree: :confused:
Old Dec 6, 2003 | 06:51 AM
MikeM's Avatar
MikeM
Larry:
I looked at pace parts. Didn't see anything applicable to my situation. Maybe I missed it.
I have a 1970 400 block with two piece rear main seal. Can I use a standard 153 tooth flywheel with the add on counterweighted plate? Where can I get the plate? Any drawbacks to using this plate?
Thanks,
Mike
Old Dec 6, 2003 | 08:01 AM
LD85's Avatar
LD85
Mike, I will look it up and post the info here.
Old Dec 6, 2003 | 08:13 AM
LD85's Avatar
LD85
QUOTE form their website" 1955-85
This lightweight 15 pound nodular iron flywheel reduces an engine's rotating inertia and quickens its throttle response. It is designed for internally balanced big-block V8s. This flywheel uses a 10.4" clutch. Its ring gear outside diameter is 12 3/4". Flywheel ID #3856579. Technical Notes: This flywheel is neutral balanced; do not use with externally balanced 454 ci engines. Use with neutral balanced torsional damper P/N 3879623. 153 tooth starter ring gear.
http://www.paceparts.com/product.asp?0=0&1=0&3=1090
Old Dec 6, 2003 | 09:45 AM
Lionsden's Avatar
Lionsden
Larry:
Thanks,
Mike
The sbc 400 is externally balanced. Unless yours has later been internally balanced you will either need a weighted flywheel or flex plate. Another option is the balance plate. These are readily available. One source is Speedway Motors
Balancing Plate S/B & 454 B/B Chevy
speedwayotors:
When running a 383 or 400 S/B Chevy with a 153 tooth flexplate or flywheel, you need to have a balancing plate. These fit between the crankshaft and flexplate and correctly balance the engine without resorting to a big heavy flywheel.
Lets you balance your Chevy small block 400 or 454 engine with a 350 flywheel (manual trans. flywheel or automatic trans. flex plate) and a bolt-on balancing plate. Road and race tested. Allows use of lighter 350 flywheel to rev quicker. Precision stamped steel.
I using a balancing plate with my 400 and don't know of a downside.
ld85s posts were confusing.
Then he says
The two statements don't add up!
[Modified by Dan Plett, 9:05 AM 12/6/2003]
Old Dec 6, 2003 | 11:10 AM
MikeM's Avatar
MikeM
Default Re: 400 small block 153 tooth flywheel (Dan Plett)
Larry: I found that flywheel but it says big block only. Thanks.
Dan: What you are calling a balance plate is what I was referring to as a counterweight. Thanks for the source. Does this take longer flywheel bolts?
FWIW: A member on another forum has advised that Jeg's sell a 154 tooth flywheel for my purpose. Haven't taked to them yet.
Thanks again.
Mike
Old Dec 6, 2003 | 11:53 AM
Lionsden's Avatar
Lionsden
Mike
I don't have a plate in front of me to measures. Just a guess I would say the plate is approx .100" thick. My bolts were long enough I didn't need different bolts.
It's possible that an aftermarket vendor sells a 153 tooth weighted flexplate.
As CFI-EFI stated there is another topic discussing this.
Old Dec 6, 2003 | 12:51 PM
LD85's Avatar
LD85
Mike
My catalog says it is for SBC, 1955-85 and BBC, 1965-1969, but regardless it is for an internally balanced setup.
Old Dec 6, 2003 | 12:52 PM
CFI-EFI's Avatar
CFI-EFI
Somehow Id85 must have misunderstood the question, because he refered to a neutral balanced flywheel. Then he mistyped, I hope, because he made it sound, to me, like he is using an unbalanced (external balance) flywheel with an internal balanced rotating assembly.
I found a site with a 153 tooth, external balance (unbalanced) flexplate, for a two piece seal crank, for Ralph. I sent him the url. Unfortunately, it is an automatic transmission builder site, and they don't list any flywheels. In my searching, I checked the Hayse web site. They didn't show 153 T, unbalanced, flywheel or flexplate for two piece seal cranks. I e-mailed them to see if they might really have, or be able to produce the flexplate. I have not had a reply. You may want to quiry them on the flywheel. Start here:
http://www.mrgasket.com/maincat.html
Good luck and...
RACE ON!!!
Old Dec 6, 2003 | 02:49 PM
LD85's Avatar
LD85
CFI-EFI is correct I did leave out one bit of info in my post above, I apologize for the confusion. I had to go back and reread what I typedn and saw the omission that CFI-EFI pointed out.:banghead:
My 400 crank is internally balanced in the front and externally balanced in the rear,,, so my stock 153 tooth Corvette flywheel was used with a balance plate and the entire setup, including my clutch,,, was balanced while mounted on the crank to within 1 gram.
:seeya
Old Dec 6, 2003 | 04:05 PM
Lionsden's Avatar
Lionsden
:thumbs:
Old Dec 6, 2003 | 06:35 PM
CFI-EFI's Avatar
CFI-EFI
Now that you explain it, I think I remember discussion of this arrangement a long while back. That is a most curious set up. Since it was spun up and balanced that closely, I can't figure what would be wrong with it. Just a curious set up. Thanks for the clarification. I was sure there had to be a "but" in there somehow.
RACE ON!!!
To 400 small block 153 tooth flywheel
Old Dec 6, 2003 | 10:59 PM
MikeM's Avatar
MikeM
If I understand this right, you are using a harmonic balancer other than the external balanced 400. On the back, you didn't /couldn't compensate and had to use the external balance plate. Is this correct?
My engine was balanced like a stock 400, external front and rear. I ran the 400 balancer and a 400 flex plate. Now I want to change to a manual transmission and go to the smaller flywheel. Based on what I have read here, all I need is the stock 350 flywheel and add the balance weight and I should be in business. Is this correct?
Mike
Old Dec 7, 2003 | 07:06 AM
LD85's Avatar
LD85
Mike, the answers are both yes and yes,,,,,,
I have a nuetral balance harmonic balancer to clear the C-4 frame, 6 3/4 inches or smaller clears the frame,, or you can indent the frame to clear
Yes you should only need to external balance your setup with the balance plate and a 153 tooth fly wheel.
Only the starter will need to be a 153 tooth but I am sure you know that,,, if you have'nt already,,,get a mini starter you will love it.
Mike I' am sorry, once again, for leaving out the data that made this easily understandable,,
:seeya
[Modified by ld85, 7:09 AM 12/7/2003]
Old Dec 7, 2003 | 09:25 AM
MikeM's Avatar
MikeM
Thanks to everyone for your help.
Mike
