Camshaft Timing - Advance/Retard Optimization
Old Jan 4, 2004 | 07:01 AM
Mr6spd's Avatar
Mr6spd
Default Camshaft Timing - Advance/Retard Optimization
It seams that nearly every off the shelf cam comes with a ground-in 4 degrees of advance. Every single engine combintation that I have simulated on Desk-top-Dyno shows best power with 0 degrees of advance (about 20-40 hp better than with 4 degrees of advance). The dyno curves also show very very little low end loss at 0 degrees of advance, and better hp from 4000 on up.
So what gives? If Desk top dyno has any accuracy, why are all the cam manufactures recommending installing them 4 degrees advanced? Am I missing something here? Is it not done because of a reduction in idle quality?
Old Jan 4, 2004 | 07:26 AM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Camshaft Timing - Advance/Retard Optimization (Mr6spd)
dont hold your breath with those desktop dynos they can be off upto and beyond 100hp :cheers:
Old Jan 4, 2004 | 11:32 AM
CFI-EFI's Avatar
CFI-EFI
...why are all the cam manufactures recommending installing them 4 degrees advanced? Am I missing something here? Is it not done because of a reduction in idle quality?
Besides the accuracy of Desk Top Dyno, it looks like you may be misinterperting the situation. As in your first statement, the 4* are ground in. If you input the grinders numbers for opening and closing points, you are inputing numbers that are 4* ahead of "straight up". If you tell DTD to advance it by 4*, you are looking at 8*. If you install it with the 4* advanced timing marks on the timing set, you will get 8* because the first 4* are "ground in".
Generally, advancing the cam gives a stronger bottom end. Advancing the cam would improve idle characteristics, at the expense of upper end horsepower. Good luck, and...
RACE ON!!!
Old Jan 4, 2004 | 12:43 PM
Mr6spd's Avatar
Mr6spd
Default Re: Camshaft Timing - Advance/Retard Optimization (CFI-EFI)
I entered the cam grinder's numbers, and then put in a -4 advance to bring the net back to zero degrees advance. CFI-EFI: What happens to your Desk-Top Dyno curves if you enter a -4 advance?
Old Jan 4, 2004 | 04:28 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In V Veteran
i put in all my cams 2-4 degrees advanced for example if it says 112 and has a 4 degree built in at straght up it will show 108 i then install at 104-106 for more power down low and dont care what the program says for a street and or street strip car you need power down low :cheers:
Old Jan 4, 2004 | 04:30 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In V Veteran
Default Re: Camshaft Timing - Advance/Retard Optimization (CORKVETTE1)
now case in hand a 1.44 60 ft and a 125+ mph is a preety good compromise considering i am only running a 307 gear :cheers:
To Camshaft Timing - Advance/Retard Optimization
