Desktop Dyno & Super Ram info
Old Jan 5, 2004 | 07:15 AM
LD85's Avatar
LD85
Default Desktop Dyno & Super Ram info
What CFM do you guys use in Desktop Dyno when entering in the "INDUCTION FLOW" info?
And I assume you use the TPI as the "MANIFOLD TYPE" ,,
thanks!
Old Jan 5, 2004 | 11:09 AM
scorp508's Avatar
scorp508
Default Re: Desktop Dyno & Super Ram info (ld85)
I use 660cfm and single plane, but none of them will be even close to accurate.
Old Jan 5, 2004 | 11:26 AM
LD85's Avatar
LD85
Default Re: Desktop Dyno & Super Ram info (scorp508)
I just wondered, the MAF sesnor only flows 750 CFM max so I assumed the Super Ram was less than 750 and the Miniram is a max of 750CFM.
[Modified by ld85, 11:28 AM 1/5/2004]
Old Jan 5, 2004 | 12:43 PM
scorp508's Avatar
scorp508
You've got to go by what the MAF can flow. Thats the bottleneck before the intake.
Old Jan 8, 2004 | 02:37 PM
Beach Bum's Avatar
Beach Bum
thanks!
Email forum member "Ralph" on this....he has a good Superram file. I know it took him quite a while to find the right #'s that put the peaks in the correct place, but his DD #'s really seem to jive with reality now.
Old Jan 10, 2004 | 10:08 PM
DragMan's Avatar
DragMan
Cruise-In VII Veteran
:lurk:
Old Jan 10, 2004 | 11:48 PM
LD85's Avatar
LD85
Default Re: Desktop Dyno & Super Ram info (Beach Bum)
thanks!
Emailed Ralph and he said he thinks this is really close:
".....the MR will have about 530hp and 470 ft lbs tq at peak. "
To Desktop Dyno & Super Ram info
