Speed-o-motive.
Im looking for 383 kits.
Im not using nitrous or supercharger.
Its a street car that sees the dragstrip around 5 times a year.
My shift points is around 6000rpm
Im going to use the LT1 intake.
Im looking at speed-o-motive stroker kits. http://www.speedomotive.com/383%20Mighty%20Mouse.htm
Is that kit to "weak" for my app?
What would you recomend?
They recomend me this kit:
1 PC SEAL SBC 383 ALL FORGED STROKER CRANK KIT
ALL FORGED CRANK KIT $1564.00
KIT INCLUDES:
4340 FORGED 3.750" STROKER CRANK
4340 FORGED 5.7" H-BEAM RODS WITH ARP 7/16 CAP SCREW BOLTS, FULL FLOATING PINS
FORGED 16cc DISH TOP PISTONS-ZERO DECK COMPRESSION RATIO = 58cc 10.5-1, 60cc 10.1-1, 64cc 9.6-1, 72cc
TOTAL SEAL MAX-MOLY DUCTILE FILE TO FIT RINGS
CLEVITE H-SERIES MAIN & ROD BEARING
Sounds like overkill for my apps. And my budget. ?
Whats your feedback?
The description of the parts, sounds, "killer". I would want assurances that they are reputable brand name items. While *I* have never dealt with Speedomotive, they have received mixed reveiws, in the past. You may want to do a search, and draw your own conclusions. Good luck, and...
RACE ON!!!
KIT INCLUDES:
for the same price you can get Eagle 4340 forged stuff and JE/SRP pistons. i prefer the 6.0" rods with the 3.75" stroke, it has more dwell time near TDC and BDC not to mention a lot less side thrust. the longer rods counter act the old "strokers can't rev" theories. Speed-O is good, but not the best bargain in town. if your looking to go cheap, look at Scat cranks, but they can be a pain to balance. Brian
oh ya, keep checking carparts.com, sometimes they run daily specials like 50% for the next couple hours. i have gotten lucky there before, Edlebrock 195cc rpm heads $580 a pair complete. good luck
My recommendations would be pay the extra for LUNATI - much better reputation. :yesnod:
