sbc main bearing question
Old Jan 21, 2004 | 12:40 PM
bob's Avatar
bob
Default sbc main bearing question
In GM specs they seem to specify a slightly tighter bearing clearance for the #1 from the #2-#3-#4. Performance builders never seem to make a difference. Anyone know why GM does it? I have always tightened #1 up a very small amount but I have done it because GM does and not with a real good reason. Anyone know the GM reason and the reason the HP builders don't?
thanks-bob
Old Jan 21, 2004 | 08:03 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: sbc main bearing question (bob)
GM had a "engine knock" problem years ago caused by the front bearing so they tighten up the specs. :chevy
Old Jan 21, 2004 | 08:17 PM
bob's Avatar
bob
Default Re: sbc main bearing question (clem zahrobsky)
thanks Clem
bob
Old Jan 21, 2004 | 09:04 PM
clem zahrobsky
Cruise-In I Veteran
i should have said the knock was caused by the engine accessories that loaded the front bearing so they tightened up the specs. :chevy
To sbc main bearing question
