oil pump primer tool
Old Feb 3, 2004 | 06:22 PM
LD85's Avatar
LD85
Default oil pump primer tool
Any gadget I can make or should I just buy a real one?
Old Feb 3, 2004 | 07:27 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: oil pump primer tool (ld85)
The critical part of this "tool" is the part that duplicates the lands in the distributor housing. If you simply turn the the oil pump, with a slotted shaft, you won't get oil upstairs on both sides of the engine. I made one, once, by grinding the teeth off the drive gear of a junk distributor. This had the advantage of the lower part of the gear, capitivating the shaft. I hacksawed the large body off of the top of the dist, and then ground the top of the shaft into a big triangle, so it wouldn't spin in the drill chuck. All sbc and bb distributors are interchangable, so just about any core will do. Good luck, and...
RACE ON!!!
Old Feb 3, 2004 | 09:00 PM
LD85's Avatar
LD85
Default Re: oil pump primer tool (CFI-EFI)
Thanks, sounds like $20 is the least effort priming my oil pump, I had heard you could do this with an old distributor, but I dont have one laying around.
Old Feb 4, 2004 | 09:57 AM
mike 1985's Avatar
mike 1985
i think Autozone has the tool, put the deposit down, use it, return it for a full refund.
Old Feb 4, 2004 | 01:26 PM
Curveit's Avatar
Curveit
Junk yard distributor, or $9.95 from http://www.powerhouseproducts.com.If you can rent one, even better.
:chevy
Old Feb 6, 2004 | 09:25 PM
LD85's Avatar
LD85
Default Re: oil pump primer tool (mike 1985)
Thanks for the reminder, picked one up today!
To oil pump primer tool
