Dragracing IRS
Old Feb 11, 2004 | 02:26 AM
stinky's Avatar
stinky
Default Dragracing IRS
Saw this browsing the web, an independant rear suspension with a Ford 9" 3rd member. http://www.kugelkomponents.com/produ...uspension.html
Old Feb 11, 2004 | 03:51 AM
Les's Avatar
Les
Default Re: Dragracing IRS (stinky)
Pricey but they look stout. How trick would it be to have one of the quick change set-ups? :thumbs:
Old Feb 11, 2004 | 11:30 AM
632C2's Avatar
632C2
This unit looks like it is aimed more at the street rod set. The half shafts, u-joints and stub axles don't look beefy enough to me to take the abuse of drag racing.
Now if you want a real drag racing IRS then go here:
www.tomsdifferentials.com/cat22.htm
Steve
Old Feb 11, 2004 | 06:43 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Here's some of Tom's stuff I put under my car :D
Old Feb 11, 2004 | 10:16 PM
stinky's Avatar
stinky
Default Re: Dragracing IRS (SmokedTires)
Nice! Waiting for my stuff to come in as we speak. Are those the 30-spline inners? Did ya get the KA outer axles as well?
Old Feb 12, 2004 | 05:44 AM
DeenHylton's Avatar
DeenHylton
Stinky,
I don't know about Smoked Tires but I bought he same center pieces as he did with the 30 spline inner axles. Worked good for two years but broke one stock outer axle this year. I now have the KA outer axles as well with 1/2" studs. You might as well save yourself some grief and just buy the whole package because if your making serious power you going to need it all to make it live any length of time.
Deen
Old Feb 12, 2004 | 06:44 AM
SmokedTires
St. Jude Donor '05
Thanks. Yes it's Tom's polished tuned posi with the large crosspin & their 30 spline inner axles. I don't have the KA outer axles as I bought new outer axles about 3 years before when I redid the rear wheel bearings. Now if I break an outer axle :rolleyes: .
While that suspension is incredible looking, I would be concerned with using it as is for drag racing because it's still only a 3 link setup like the stock C2 & C3. The problem is that you should also have a link added to the top of the wheel assembly for support. If you ever break a u-joint, half shaft, axle, you loose control of your wheel & it can flop back & forth (\|/) with the lower strut rod acting like a hinge. Not a good situation ;)
:cheers:
[Modified by SmokedTires, 6:52 AM 2/12/2004]
Old Feb 12, 2004 | 02:57 PM
stinky's Avatar
stinky
Default Re: Dragracing IRS (DeenHylton)
Yup, I've got the KA outers coming as well. What level of mods did you have Toms perform on your posi unit...I see he offers 2 thru 7. I'm trying to determine what to have done with respect to clutch pack or no.
Old Feb 12, 2004 | 05:57 PM
1991Z07's Avatar
1991Z07
Just got off the phone with the owner of Kugles and he said that the center section, modified to fit a C4 frame, would run about $2000.
That is just about the same as it costs for Tom's to build me a complete cryoed D44....
And I don't know if you guys have been in a cave for a long time, but a Ford 9" is about one of the stoutest rear-ends around. These come with 31-spline axles, hardened.
Old Feb 12, 2004 | 11:45 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
If you get creative, you can do some pretty wild things. I have a Dana 60 IRS under my '67. It's based on a NOS Hemi case that was modified into an overgrown Vette diff assy. It has 35 spline axles, 3.5"x.134 wall halfshafts and Toms 31 spline outer axles.
If you aren't paying attention most folks don't notice that is what it is until you tell 'em to look close. Sneaky...it looks just like a Vette setup from the rear.
Let's see.....Vette- 8.2" ring gear...12 bolt- 8.875 ring gear...8-3/4" Mopar.....9" Ford........THEN the Dana 60- 9-3/4"!!!
I'm thinking it should hold for a while!
JIM
Old Feb 13, 2004 | 06:28 AM
SmokedTires
St. Jude Donor '05
I went with the stage 6 part number 10V-3P-630 with the large cross pin. The only thing I didn't get was the specially heat treated spider gears, I don't understand that because it wouldn't make since to use non heat treated gears unless they're just including a cryogenic process in there. My guess is that most of these spider gears heat treated in a salt bath.
http://www.tomsdifferentials.com/cat18.htm
Old Feb 14, 2004 | 05:02 AM
DeenHylton's Avatar
DeenHylton
Stinky,
I went with the level 7 with oversized hardened pin but am having second thoughts about the "tuned" clutch packs. I think I should have left the spring pack in to compensate for the wear on the clutch frictions. I'm noticing less posi "action" now that I have 80 plus runs on the car. You do need the better clutch frictions as the material is less likely to break off under severe use (according to Tom) but the tuned part needs to be retuned every so often in my humble opinion.
As others have posted don't forget to add a six-link to your IRS if running 10.99 or quicker. I fabbed my own using "VB Products" racing strut rods in both the upper and lower positions. For more info on this subject do a search on 6-links as this has been discussed a number of times.
Deen
Old Feb 14, 2004 | 08:06 PM
stinky's Avatar
stinky
Stinky,
Deen
Thanks for the input, Deen, and, yes, I have my 6-link in hand (the Canadian one) and big tube half-shafts on the way.
Old Feb 15, 2004 | 11:00 AM
1991Z07's Avatar
1991Z07
Stinky,
The stock C3 rears can hold 1000 HP and run deep into the 9's. One of our NCCC friends have been running his 67 BB for over ten years on a stock config. rear. He changes the universals every 30 passes, needed or not. Seems to be a lot easier than changing to a 6-link.
His motor dynoed at 1021 HP (N/A) and he runs low 9's in the 1/4.
Old Feb 16, 2004 | 05:36 AM
DeenHylton's Avatar
DeenHylton
Default Re: Dragracing IRS (Joe90)
Joe90,
NHRA requires you to eliminate the IRS or mod to a 6-link too run faster than 10.99
If your buddies are allowed to run a stock rearend in the "low 9's"...then your racetrack is not a NHRA member track or the safety inspection team is sleeping on the job :sleep:
Deen
Old Feb 16, 2004 | 09:50 AM
1991Z07's Avatar
1991Z07
He runs that car in NCCC events...
His IHRA/NHRA tube-frame vette has a 6-link in it though...
Old Feb 18, 2004 | 01:04 AM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
Joe90,
Deen
i believe the stock irs on the c-4s are legal down to 9.99 :cheers:
Old Feb 18, 2004 | 10:26 AM
CFI-EFI's Avatar
CFI-EFI
Default Re: Dragracing IRS (CORKVETTE1)
The C4 IRS is good for as fast as you can go. However, at 10.99, halfshaft loops are mandated.
RACE ON!!!
To Dragracing IRS
