Horizontal vs Vertical Roller Locking Bar
Old Feb 16, 2004 | 08:18 PM
VETDRMS's Avatar
VETDRMS
Default Horizontal vs Vertical Roller Locking Bar
I am looking to change my HR to a solid roller and was wondering what the pros/cons are for these two types of locking bars.
The horizontal "pop-up" bars are less expensive and allow cam changes without manifold removal, but I have heard that the vertical locking bars are better.
I was considering Comp's 818-16 lifters as they aren't too pricey $265 (vertical).
The Crane lifters (horizontal) are $225
Thanks :cheers:
Old Feb 16, 2004 | 08:23 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Horizontal vs Vertical Roller Locking Bar (VETDRMS)
Thanks :cheers:
the horizontial bar setup is alot lighter also just make sure you get some kind of oil hole down to the roller bearing and do not put in restricters :cheers:
Old Feb 16, 2004 | 08:27 PM
VETDRMS's Avatar
VETDRMS
Default Re: Horizontal vs Vertical Roller Locking Bar (CORKVETTE1)
By oil hole are you refering to something like using an oil-groover to put a groove in the lifter bore? The main oil returns over the cam have been chamfered if that's what your refering too. Excuse my ignorance.
:cheers:
Old Feb 16, 2004 | 09:08 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In V Veteran
some has a groove some has a pressure hole very tiny to get some oil down on the roller bearings :cheers:
Old Feb 17, 2004 | 12:06 AM
VETDRMS's Avatar
VETDRMS
The Crane 11519-16 have an oiling hole to route oil to the roller. I found them for $189 online.
:cheers:
[Modified by VETDRMS, 10:07 PM 2/16/2004]
Old Feb 17, 2004 | 01:11 AM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In V Veteran
:cheers:
Old Feb 17, 2004 | 10:23 AM
gkull's Avatar
gkull
My 383 has the Crane pro verticle which I got at cost + shipping. They have been running for about a year now. For my new 427 I installed the new Crane Pro horizontal they were about $550.
Crane has an excellant warranty program. I trashed a set of rollers and they gave me the Crane pros at cost for sending mine back. So delivered to my door they were about $370.
My latest springs are @180# closed and 540# open at .620 lift
To Horizontal vs Vertical Roller Locking Bar
