Pleas help on BB piston\rod installation.
Old Mar 24, 2004 | 10:51 PM
ImBatman's Avatar
ImBatman
Default Pleas help on BB piston\rod installation.
http://forums.corvetteforum.com/zerothread?id=783775
Old Mar 25, 2004 | 08:53 PM
norvalwilhelm's Avatar
norvalwilhelm
Default Re: Pleas help on BB piston\rod installation. (BlackRat)
The bearing insert is not centered when installed in the cap and rod. This offset of the bearing is to keep it off the radius of the crank. Install the rod so this offset is next to the crank and the side where the bearing is almost flush with the rod is the side facing the other rod.
