383 oil pan question
Old Apr 12, 2004 | 09:36 AM
Surfer69's Avatar
Surfer69
Default 383 oil pan question
I notice many people getting the 7 quart Moroso pans for their 383. Will the stock pans work or do they need mods where block gets grinded? Why is 7 quarts that great?
Old Apr 12, 2004 | 08:40 PM
Pete K's Avatar
Pete K
Default Re: 383 oil pan question (Surfer69)
On my 87 I had to persuade w/ball peen hammer. Otherwise it worked fine :D
Old Apr 14, 2004 | 01:06 PM
71coupe's Avatar
71coupe
I beat out my pan on the 383 I had, never sealed too good after that :lol:
Old Apr 14, 2004 | 01:38 PM
lowvette's Avatar
lowvette
I’m using a 350 SBC stock oil pan on my 383. I built the engine in 1992 and have not experienced any problems. If you’re making a lot of heat, an oil cooler would be more effective.
:auto:
Lowcountry Corvette
www.LowVette.com
Old Apr 15, 2004 | 04:35 PM
VETDRMS's Avatar
VETDRMS
I had no clearance issues with my Moroso 20191 7qt pan. It is clearanced for strokes up to 3.850"
Old Apr 16, 2004 | 09:43 AM
Surfer69's Avatar
Surfer69
Default Re: 383 oil pan question (VETDRMS)
Do you need special oil pump with those pans? Also does stock dip stick still measure correct?
Old Apr 16, 2004 | 11:47 AM
gkull's Avatar
gkull
Your dip stick is the same. The full level is the same no matter how deep the pan is.
Your pump is the same. Only it needs a pickup tube for the specific pan.
To 383 oil pan question
