Carburation question
Old Apr 21, 2004 | 05:21 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Carburation question
I'm planning on having a 600 - 650 HP small block built..
Here are details:
406 small block with 11:1 compression, solid roller cam with .676 lift and 264/270 degrees .050 duration, Dart Pro-1 230 cc heads - stage II ported and matched to 1206 gasket, victor Jr. (matched to 1206 gasket) with 1/2 inch spacer.
What size carb should I get... I'll either get a 950 HP series carb or a 1050 dominator... I wonder what will be better for my application?? I know that 950 cfm should be enough.. but I might get more HP with the 1050 - correct??
Desktop dyno comes up with approx. 600 HP with untouched Dart Pro I heads.. I'm sure that the porting will add some more HP...
[Modified by GrandSportC3, 5:22 PM 4/21/2004]
Old Apr 21, 2004 | 05:28 PM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Default Re: Carburation question (GrandSportC3)
Oliver,
My last 454 made right at 500 rwhp (with a carb spacer). I think a very honest flywheel HP estimate would be 625 or so. I ran mine with a 1000 hp series. No that a Dominator can not work on the street, but for your hp goals it is probably not needed. A nice feature of the HP series is they have adjustible air bleeds, makes them easier to tune on both end of the rpm range.
The HP series flow less than what they advertise. I believe the 950 flows around 830 or so and the 1000 flows around 950-980.
Old Apr 21, 2004 | 07:36 PM
GrandSportC3
Default Re: Carburation question (69 N.O.X. RATT)
Oliver,
I'll get the 1000 HP series then.. Thanks!! :cheers: :cheers:
Old Apr 21, 2004 | 09:47 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
A 600-650 hp small block is a serious piece and that cam is going to like to rev.
I'm sure you can make the power with a well set up HP1000 ( I like them too) but the Dominators usually outpower a 4150 carb slightly. You're going to be moving lots of air, so a well tuned carb is going to be essential.
The Dominator can be made to work on the street without too much effort. I think the 4150 would easily suit your HP needs, but so would a Dominator and would likely help just by design of spreading the venturis out further.
Plus they look so cool!!!
JIM
Old Apr 21, 2004 | 10:46 PM
69ttop502's Avatar
69ttop502
Default Re: Carburation question (427Hotrod)
Jim, I am curious. Is a Dominator taller than a 4150 carb. I am right at the limit of hood clearance with my setup now. I would love to try a Dominator but a new hood is out of the question at this time. Sounds like a great engine Olivier. Glad you didn't sell the car too.
Old Apr 22, 2004 | 11:19 AM
tshort's Avatar
tshort
CI 7-8 Veteran
Olivier, why the Victor Jr and not the Super Victor? And is Mark building your engine?
Old Apr 23, 2004 | 12:50 AM
GrandSportC3
JIM
The main problem with the dominator is that I'm not aware about any drop base setups that are available.. so I will probably go with a built 1000 cfm HP series carb..
Old Apr 23, 2004 | 12:52 AM
GrandSportC3
Default Re: Carburation question (tshort)
The Super Victor would not fit under my hood.. The highest possible combination is the Victor Jr. with 1/2 inch spacer.. If I want more power at one poing.. I might cut the hood and use a higher intake...
Yes- Mark is going to build the new engine... I'm just waiting to get my money from the '98 Vette sale...
Old Apr 23, 2004 | 01:55 AM
69 N.O.X. RATT
Hey Oliver....I know how to take care of your horsepower needs for well under 500 bucks... :yesnod:
Old Apr 23, 2004 | 11:33 AM
GrandSportC3
Does this mean that you have a carb for me?? :confused: :confused:
Old Apr 26, 2004 | 01:07 PM
Kevin Mason's Avatar
Kevin Mason
I think it means he is going to recommend nitrous.
Old Apr 26, 2004 | 07:01 PM
69 N.O.X. RATT
Default Re: Carburation question (Kevin Mason)
Yup
Old Apr 27, 2004 | 02:13 AM
427Hotrod's Avatar
427Hotrod
I got my drop base air filter from Ram Air Systems in Canada. Check out their website. Lots of combinations. Mine is a 2.5" drop with a 4" tall filter and is 16" diameter.
There is another place that Steve B (542C2) used to get his from. You might ask him.
I "think" the Dominator is a little taller, but I can't remember how much. Maybe a 1/4" or so?
JIM
Old Apr 27, 2004 | 02:41 AM
J. Swisher's Avatar
J. Swisher
You wouldnt happen to have an web adress for Ram Air Systems?
Old Apr 27, 2004 | 11:05 AM
GrandSportC3
No nitrous for me... If I'd add nitrous - I would very likely run in the 9's and I don't want to run 9's because I'd need a full cage and lots of other stuff that I don't want to install...
Old Apr 27, 2004 | 11:07 AM
GrandSportC3
Default Re: Carburation question (J. Swisher)
:withstupid:
Old Apr 29, 2004 | 12:43 AM
skid's Avatar
skid
http://www.ramairbox.com I am using their open top setup on my cowl induction 74 hood. It seals to the bottom of the hood and draws only fresh air.
To Carburation question
