Do I need a small base cam with this kit??
Old Apr 25, 2004 | 02:33 PM
devilfish's Avatar
devilfish
Default Do I need a small base cam with this kit??
http://www.flatlanderracing.com/stro...v-350383c.html
Or can I use my hot cam with this kit??
Old Apr 25, 2004 | 07:00 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Do I need a small base cam with this kit?? (devilfish)
You shouldn't need a reduced base circle cam with any 383. Once you mock up the assembly, with the cam degreed where you want it, check for .050" minimum clearance with the rods. Any "adjustment" necessary can be made by grinding the connecting rod bolts or rods, themselves, depending on the rod you select.
RACE ON!!!
Old Apr 25, 2004 | 10:15 PM
danno85's Avatar
danno85
I agree with CFI-EFI, and it depends on which rod you get. There are
4 different rod options listed on your link, and if you go to the SCAT web site they
say that their H-beam rod and the 7/16" bolt I-beam rod are stroker
clearanced. They don't say that about the regular I-bean rod, but that
doesn't mean it wouldn't clear on with a 3.750" stroke crank and a
hot cam.
Dan
Old Apr 26, 2004 | 02:50 AM
devilfish's Avatar
devilfish
Default Re: Do I need a small base cam with this kit?? (danno85)
thanks!!
To Do I need a small base cam with this kit??
