Cam bearings install question
Old Apr 28, 2004 | 02:35 PM
Surfer69's Avatar
Surfer69
Default Cam bearings install question
Can I install new bearings myself in new block or do you need special tooling engine shops say they have to install? :confused:
Old Apr 28, 2004 | 04:59 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Cam bearings install question (Surfer69)
you need a cam bearing installing tool and they cost more that having a shop install them. make sure you take you cam also so they can check to make sure the cam will go in.
Old May 2, 2004 | 08:53 PM
norvalwilhelm's Avatar
norvalwilhelm
Besides needing a special dedicated tool there is also an order for installing. The machine shop charges very little for this operation. Let them do it.
Old May 2, 2004 | 08:54 PM
norvalwilhelm
Forgot you also have to make sure the oil holes line up as best as you can, even if a machine shop installs the bearings check cam fit and oil hole alignment.
Old May 4, 2004 | 09:26 AM
Surfer69's Avatar
Surfer69
Default Re: Cam bearings install question (norvalwilhelm)
Thanks Norval, I'll definitely check that. :thumbs:
To Cam bearings install question
