i bought a 3310 for my carbed 355 . I have had a stumble of even slight popping when trying to slowly accelerate. Meaning if i'm going 50 and want to speed up to 52 it stumbles and even slightly noses over first then goes. To cure this i've had to go from the 70 stock jets in the primary to 75's. Is this normal or do you think something else could be wrong with the carb ?
The jet change was in the primaries, only, right? If that solved the problem, you're probably fine. Otherwise, you could fine tune the accelerator pump, and maybe be able to jet back down. The hesitation IS a lack of fuel in the transition.
Make sure that the shot from the accellerater pump occurs as soon as the throttle moves. Even a slight delay can cause the problem you described. If needed, the adjustment is a simple twist of a screw.
That is what I was refering to. Also the pump cam can be installed in two different positions. There are opyional cams and shooters available, also.
I hope that is a pretty highly modified engine. The 3310 is a vacuum secondary, 750 cfm, isn't it? That is pretty big for 355 cid. If it has high gears (numerically low) the idle circuit may still be in play at 50 mph.
i have played and played with the cams, squirters, even have gone as high as a #37 tube type and preloaded the acc pump 1/2 turn. I have found the blue cam in the #2 position to be the best with the stock #31 squirter. Your probably right about the idle circuit, 1/4 turn out or in makes a difference as to how the car runs. It prefers out.
The issue i'm working through right now is at 4200-4300 RPM when at WOT it just sort of hesitates. This seems to only happen when accelerating hard from a dead stop. I have a 0-60 timer on the speedo. So i'm trying toi tune through that with the secondary springs and jetting ( i have bought the secondary metering block) Right now i have 75 primary and 78 secondary.
The combo is
355
9.3-1
180CC Dart iron eagles
224-235 @ .050 112 LSA 495-510 lift
weiand staelth dual plane
750 VS carb...choke horn milled off
turbo 350
10" 2800 stall
3.07 geras
26" tall tire.
1-3/4 " long tubes with 2.5" ex.
The big ex. is because i plan to spray 200 to it when i get the motor right.
My friend has a 650 DP i might try too, i'm thinking the 750 might be too big.
The combo is
1.) 355
2.) 9.3-1
3.) 180CC Dart iron eagles
4.) 224-235 @ .050 112 LSA 495-510 lift
5.) weiand staelth dual plane
6.) 750 VS carb...choke horn milled off
7.) turbo 350
8.) 10" 2800 stall
9.) 3.07 geras
10.) 26" tall tire.
11.) 1-3/4 " long tubes with 2.5" ex.
Not to be critical, but I think you have some serious mismatches in equipment, here. First, the cam is quite large for the compression ratio. You have a manifold best suited for a low to mid range combination with a carb, cam and headers, better suited to HIGHER rpm duty. Regardless of the rpms or N2O, the headers are too big. Try the 650 DPer. I think you'll find some improvement. Good luck, and...
actually the cam power range is 2500-5500, the intake idle -6800 and one of the few that fitr under the stock hood. and a that's why i went with the 750 VS carb, opens the secondaries as needed. I plan to try the 650 this weekend and i'll get back with the results.
the headers most likley are too big, but what if the car has a 406 in it 3-5 yrs from now ? Or i may just trade them on the board for smaller ones.
The comp had to be 9.3-1 due to pump gas and iron heads, in retrospect i should have bought a smaller cam
