educate me on rod length please.
Old Jul 29, 2004 | 05:10 PM
blackLS1's Avatar
blackLS1
Default educate me on rod length please.
How do you determine rod length for your sbc aplication?I have seen 5.65/5.7/6.0 rod lengths.What dictates their use?
Old Jul 29, 2004 | 11:33 PM
comp's Avatar
comp
the length from the center of the big and little ends
Old Jul 30, 2004 | 12:30 AM
blackLS1's Avatar
blackLS1
Thanks bro.
Old Jul 30, 2004 | 04:04 PM
90NormZ51's Avatar
90NormZ51
Rod length, stroke, and piston compression height must fit within the deck height of the block. I don't know the Gen III deck height, but the Gen I & II blocks are nominally 9.025" from the centerlne of the crankshaft to the top of the block deck. At TDC the length of the piston rod assembly on the crankshaft is 1/2 the stroke + rod Length + piston compression height (the distance from the centerline of the wrist pin to the top of the piston). So for example, a 383 stroker (3.750 stroke) w/ 6" rods requires a piston compression height of 9.025 - (1.875 + 6.0) = 1.15" (approximately for the piston flush with the deck). A piston CH of 1.125 would leave the piston 0.025 down in the bore. Many people deck the block flat to 9.00 height when they rebuild which would give a piston of 1.125 compression height. Look in the piston catalogs and you'll this is much more common than 1.15".
Old Jul 30, 2004 | 06:40 PM
comp's Avatar
comp
i wish i could explain this so well
Old Jul 30, 2004 | 06:42 PM
blackLS1's Avatar
blackLS1
Thanks for the explanation.
To educate me on rod length please.
