Ok so i picked up a MSD 6TN from ebay for a c note., download the istructions but it dosent seem quit right. i want to hook up to my points , see if there is a difference
the instructions:
the box:
ther connector:
in the instructions they identify wires 1 as magnetic pickup. good don't need it right now.
under that they indicate a tach output. that is where i have wires 2
wires 3 is for a rev limiter attachment, don't need it right now.
when i get to the right side, or number 4 wires i get confused. the six wires they show indicate 2 heavy black and red wires. like what i have coming out of the tach output. the other 4 are OK except i have a brown not a white. lets figure the color is just switched. still the other 2 indicated as "heavy wires" are the same gauge as the other 4 and the colors don't match. like i said , just dosen't seem right. any ideas.
never mind i found a download on there site. the instructions i had were worthless. my unit has the NASCAR mandated 6 pin connection so it changed everything.looking up another pro race unit i found the appropriate schematic. there downloads are just behind the time. if you are curious just go to www.msdignition.com , downloads , pro race HVC 6600
_________________
