Piston choices
Old Aug 2, 2004 | 05:32 PM
adam's Avatar
adam
Default Piston choices
I've been looking at pistons for a street/strip motor.
I'm targeting a motor at about 380HP, trying for 300RWHP.
I'm only looking at the hypereutectic pistons - flat tops.
I've found that Keith Black sells two for a 350/355 - KB120 and
KB231. The '231s are supposedly lightweight - 485 g vs 535g.
The silvolite claimers are also about the same price as the KB's.
Also, Speedpro sells '345 - a cheap rebuild type, and the '631 a
coated skirt hyper.
Of these I want a set with only 2 valve reliefs - that rules out the 345's.
Any other things to consider between the Speedpro's and the KBs?
Is the lighter weight KB's worth the $60 difference?
Anything else to consider about pistons?
Thanks.
Old Aug 2, 2004 | 11:22 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
KB's usually require file fit rings I went with the uncoated SpeedPro they have benn making pistons for long time.
Old Aug 3, 2004 | 04:43 PM
h rocks's Avatar
h rocks
coated skirt hyper.
Thanks.
Have never heard anything good about KB pistons...I know a guy that dropped one on the floor and it busted apart like a china cup. I would get the best that you can afford.
Old Aug 3, 2004 | 06:01 PM
panchop's Avatar
panchop
well that sucks since i just finished stuffing a set in my block. guess I'll find out.
Old Aug 3, 2004 | 06:18 PM
comp's Avatar
comp
i'd go with the lighter one if mine
Old Aug 6, 2004 | 05:16 PM
adam's Avatar
adam
Guess most here use forged pistons...
> get the lightest...
Well, comparing the lightweight KB to the coated speed-pro piston,
the KB (231) would be 1080g's lighter. (587g KB vs 722g SP - I estimated
that the SP is 582g and the pin is 140g, I couldn't find the weight of the
coated piston, only an uncoated version, nor the actual pin weight.)
It appears that the lightweight KB piston includes a lightweight pin
that weighs 102g vs. 140g for a standard KB piston.
Does anyone know the weight of a speedpro hyper piston (H631CP) ?
The company web site doesn't list weights...
To Piston choices
