Timing gear?
Old Aug 4, 2004 | 10:32 AM
ZD75blue's Avatar
ZD75blue
Default Timing gear?
Hi guys...
I'm wondering if its necissary to replace the timing gear on the crankshaft snout. I am having a heck of a time getting it off the crank! I tried a gear puller that was a touch to big (had to put a socket on end of the snout for it to have leverage.)
Do I need to replace it? What size puller do I need to easily get it off if it must be replaced?
What brand timing chains do you guys like?
Old Aug 4, 2004 | 12:21 PM
comp's Avatar
comp
replace what type of puller's do you have
Old Aug 4, 2004 | 12:58 PM
ZD75blue's Avatar
ZD75blue
If you can recomend some...
I think it was a drum brake puller... but it was borrowed...
What sizes/brands are recomended?
Old Aug 4, 2004 | 06:24 PM
CFI-EFI's Avatar
CFI-EFI
I would replace the whole set. A jaw type gear puller should work. You can probably borrow one from one of the chain, parts store near you. I have always had success with a pry bar. Two pry bars to equalize the force on both sides with the most stubborn.
RACE ON!!!
Old Aug 4, 2004 | 06:39 PM
ZD75blue's Avatar
ZD75blue
Are you using pry bars while its in the block?
Cause mine is already laying on the floor... well standing on the floor... heard you can warp em if they lay sideways to long.
I'll look into some pullers!
What brand chains do yall run?
Old Aug 5, 2004 | 11:30 AM
CFI-EFI's Avatar
CFI-EFI
In the block, even with the block on the car. I changed my timing set, only, this spring.
Warp what? The pry bar???
OH! The crank is on the floor. You might have mentioned that in the first place. That makes it a little harder to wrestle with. Pry bars, punches and a hammer, or if all else fails, a three jawed, gear puller.
It's hard to beat a good old Cloyes timing set. I used a stock truck set, which is a double row, roller chain. THIS one even had three key ways on the crank sprocket, and was under $20.00.
RACE ON!!!
Old Aug 8, 2004 | 09:57 PM
ZD75blue's Avatar
ZD75blue
I've heard good things about cloyes as well...
But, the question must be asked... Rolls Royce silver clouds used timing gears. Gears dont normally break.
Are they worth the added harmonics introduced to the engine for no chance of stretch occuring?
To Timing gear?
