siamesed block
Old Aug 12, 2004 | 07:23 PM
hubes's Avatar
hubes
Default siamesed block
what is the difference between a siamesed and non-siamsed block? I know the siamesed blocks can accomodate a larger bore, but why? and are there any other advantages? thanks
Old Aug 12, 2004 | 07:56 PM
71coupe's Avatar
71coupe
Since the bores are bigger - like the original 400, there was no room left for the water jacket between the cylinders. They joined the cylinders together in the casting & added "steam holes" in the heads.
400's cyl's had a problem of not staying round after heated up due to this. I don't think Bowties or aftermarket HD blocks have this problem even though they are siamsed.
