Headers, headers, headers,
Old Sep 20, 2004 | 06:37 PM
Irish Whiskey's Avatar
Irish Whiskey
Default Headers, headers, headers,
With a procharger blower is it a good idea to add headers? Why? Won't this increase the level of boost or will it keep the boost in the 7psi range?
Old Sep 20, 2004 | 06:42 PM
CFI-EFI's Avatar
CFI-EFI
Yes. Headers help get the bad air out to make more room for the good air.
RACE ON!!!
Old Sep 20, 2004 | 07:55 PM
SWCDuke's Avatar
SWCDuke
Headers are of marginal value in a supercharged application. The point of headers is to create exhaust port pressure that's less than inlet pressure during the overlap period, but in a supercharged application inlet pressure is always positive at WOT so exhaust wave dynamics aren't that important. Also, you don't need or want a high overlap camshaft.
A good set of free flowing manifolds or short tube headers are a better bet than long tube headers designed for a natuallly aspirated application. On a supercharged engine achieving low average backpresssure is more important than harnessing the exhaust wave dynamics.
Look at any supercharged racing engine. The exhaust pipes aren't merged into a collector and they're just long enough to be reasonably certain that the exhaust gases are directed away from the car.
Duke
Old Sep 21, 2004 | 11:28 PM
L79vette's Avatar
L79vette
I'd agree if I'd ever seen shorty headers or manifolds that looked decent. All Chevy exhaust manifolds have sharp turns that hurt flow. Shorty headers seem to all have terrible collector designs too. Very steep merging angle.
I'd buy long tube headers, only for the gentler bends and good collectors. No worries about equal length primaries.
Old Sep 22, 2004 | 01:21 AM
SWCDuke's Avatar
SWCDuke
Good point, but long tube headers actually have quite a bit of friction. For a supercharged application getting the exhaust into the full size exhaust pipe as quickly as possible will minimize wall friction. The 2.5" rams horns are actually pretty good and they can be ported and port matched to the heads.
If it were me I would survey the market for the best flowing manifolds available.
Duke
Old Sep 27, 2004 | 11:25 AM
SWCDuke's Avatar
SWCDuke
Default High flow manifolds
Check out the following link:
http://www.castheads.com/exhaust_fol...haust_set.html
Duke
Old Oct 3, 2004 | 09:43 AM
Irish Whiskey
Thanks for the info - I'll probably just stay with the stock headers and put money into someother place. The new Fastech LSX intake manifold may be a better place to put my money with either the 78mm or 90mm throttle body. Let me know what you think
Old Oct 3, 2004 | 02:10 PM
comp's Avatar
comp
RACE ON!!!
SIMPLE and True
Old Oct 3, 2004 | 09:23 PM
mdhmi's Avatar
mdhmi
Long tube headers will most definitely help in a supercharged car - especially with torque.. Also LT's will, IMO, be more beneficial than a larger TB.
Good luck,
Mark
Old Oct 14, 2004 | 07:41 AM
Ganey's Avatar
Ganey
Yes for performance. The less backpressure the better.
To Headers, headers, headers,
