Guys I am going to build a 406 and have a ? about CR. I want to still be able to run pump gas in the car what is the max CR I can go, I plan on using aluminum heads but am not positive. It will be fuel injected with a superram intake, and LT headers. The car is a 87.
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
With a cam like that you need 11:1 CR and get the bigger heads I have 2.08 intake valves. The torque is there with a 406ci so build some horsepower, I had 360ft/lbs of torque at the rear wheels at 2000RPM where my dyno run started and it went to over 400ft/lbs
Motorhead and ID85 do you guys run pump gas? Also are you guys using 5.7in or 6in rods?
I am not positive on my combo yet so alot can be changed. I am trying to get my hands on a block right now. I have located two one has been hot tanked,magnafluxed, pressure tested the has been hot tanked, magnafluxed, shot blasted and sprayed with rust protectant they both cots $300-$500.
Don't know about a 406, but on my 383 I'm running 11.94:1 and it's on the borderline. I'm running alum. heads and .037 quench and a cam with alot of overlap.
It pings some in the summer under full load if I don't back out some advance. Wintertime and cooler air it does ok.
Stick with 11.5:1 or lower and a tight quench and you should be fine on pump gas in all conditions. I would say a tight quench is mandotory on anything over 10:1
Yes I run 5.7 rods and Ol'RJ has a 11.0:1 and he has 6.0 rods and he runs pump gas too.
I run 10.1:1 with the AFR 195's and while I was playing with the recurve kit on a hotter than heck day I did hear slight pinging. This happened only once and I've since limited my vacuum advance to only 10 degrees.(total mechanical is still 35)The point I am trying to make I guess is that octane tolerance is subjective to the fuel quality as well as the temperature,as well as the load the engine is under.I have quite a margin with only 10.1:1 to run well even if I get a tank of crappy gas.The cam is a Comp XE-284 running 1.60 rockers,so if you look at the lift and duration it's right up there with the roller cams I've seen cropping up lately.
[QUOTE=ralph]I'm at 11 with no problems. If i had to do it over id go 11.5. I think the higher compression makes more of a difference than most people think.
QUOTE]Amen! I too think the higher CR is worth more than the calcs say
I run 5.7 rods and 93 octane, I had my timing set by accident at 45 degs
when I first fired it up and no pinging, personally I wouldn't go above 11:1 CR gains aren't worth the trouble if you have detonation problems
I run 10.7:1 with AFR heads and .039" quench. I run on 91 octane with 38 degrees intial and total timing. No pinging.
This is with 6" rod and SRP flat tops.
Motorhead: I shift at 7200rpm, I can hear my crank weeping when I park it. ROFL
Thanks for all the help guys. I have found yet another block on ebay (Item# 7925772441), but I am a little uncertain they say it has been
"THERMALLY CLEANED AND SHOT PEENED, MAGNUFLUXED, BORED AND TORQUE PLATE HONED TO .030, AND THE DECKS OF THE BLOCK HAVE BEEN MILLED. THIS BLOCK IS TRULY READY FOR SOMEONE TO BEGIN ASSEMBLY"
If I do end up getting this block what should be done to check it out before I start assembly.
Usually, when the block in finished honed, the shop wants the pistons on hand to custom fit each hole to a specific piston. Also, the cylinder hone, finish, is for a certain type of ring. You might inquire what rings the cylinders are finished for. You might ask if there is enough meat left to custom fit the pistons. OR depending on how you are building it, do nothing.
"DECKS OF THE BLOCK HAVE BEEN MILLED" What does THAT mean? Are they simply flat? Have they been trued and squared? Is the block decked to some particular "deck height"? Or piston to deck clearance? Again, you may not care.
As i understand it from my friends 383 and a ported superram. your very limited on total ci, head type, and cam duration.
The super ram has upper rpm limits because it's cfm flow is so low. It's tuned design limits cam duration to less than 226 @.050 Most guys use 219/219 cams and only 383 or so ci
The superram is like restrictor plate racing. Sub 6200 rpm on a 383 so they are suited to use lower duration h-roller cams.
