Trouble with Fluidamper installation...
Old Oct 4, 2004 | 01:23 PM
Doug Brandon's Avatar
Doug Brandon
Default Trouble with Fluidamper installation...
We are using the correct tool, but starting to pull metal shavings off the crank (with about 1/2" to go). This is a new Scat 4340 crank, and a damper I pulled off my 433.
Will heating or cooling the damper make any difference before we try again tonight? Seems like cooling it would cause the metal to slightly contract and widen the ID. Any suggestions?
Old Oct 4, 2004 | 05:16 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
You're going to HAVE to hone it. Don't take a chance on splitting it!! They almost always have to be honed to fit the crank. They are made undersized slightly so that they can fit all cranks. I'm actually surprised it fit the stock one without honing, but apparently there is a huge difference in tolerances in all the factory and aftermarket stuff.
You can take it to a machine shop to be done in a couple of minutes on a rod re-sizing machine, or you can do it in a few hours with a brake cylinder hone and LOTS of patience!
JIM
Old Oct 4, 2004 | 06:05 PM
comp's Avatar
comp
mic. them
Old Oct 13, 2004 | 07:28 PM
eptaylor's Avatar
eptaylor
If you still want to try it you need to HEAT the damper and freeze the crank. Heat is probably not a good idea here so best to go with the hone.
Old Oct 14, 2004 | 02:28 AM
71coupe's Avatar
71coupe
I was able to get my fluidamper with lots of aerospace quality anti-seize & smooth movements with the install tool.
Old Oct 20, 2004 | 03:41 PM
Brettmc's Avatar
Brettmc
JIM
The directions on Fluidamprs website says to hone to fit. If I remember right the clearance is supposed to be .0005".
Brett
Old Oct 21, 2004 | 12:19 AM
427Hotrod's Avatar
427Hotrod
Not clearance....they probably mean .0005 interference fit. The balancer should be about .0005 smaller than the crank.
JIM
Old Nov 3, 2004 | 11:46 PM
Corvette0096's Avatar
Corvette0096
hone it
Corvette0096
hone it
Old Nov 4, 2004 | 10:51 AM
Doug Brandon
Default Balancer
Thanks. Hone and clean up did the trick.
Motor and trans are in car-finally. Now just have to install heads, intake, etc...TKO500 fits like a glove. Hope to hear some music this weekend.
Old Nov 4, 2004 | 10:53 AM
CFI-EFI's Avatar
CFI-EFI
JIM
If you hone it, be VERY careful. If you get it too big, it will be functionally, worthless.
RACE ON!!!
Old Nov 7, 2004 | 04:44 AM
comp's Avatar
comp
PIC'S
To Trouble with Fluidamper installation...
