ZZ4 cam
Old Oct 11, 2004 | 10:52 AM
comp's Avatar
comp
Default ZZ4 cam
anyone know the spec's???
Old Oct 11, 2004 | 06:10 PM
sjaroslo's Avatar
sjaroslo
From: And make no mistake, there's women who just wait for the man and machine with the best time
St. Jude Donor '08
From the GM Performance Parts web site http://www.gmgoodwrench.com/perfpart...on=ce#24502609 :
"To compliment the cylinder head design, we've incorporated a steel roller tappet camshaft with .474" intake and .510" exhaust valve lift. The combination makes 355 horsepower at 5250 rpm and has that great sounding muscle car idle, with just enough lope to let people know that this is no station wagon engine."
Camshaft ........................ 10185071 Hydraulic roller
Lift .474" I, .510" E.
Duration @ .050: .208o I,
.221o E.
"10185071 Hydraulic Roller Tappet
This hydraulic roller tappet is used on the 5.7-liter H.O. 350 ZZ3 & 4 engines. The duration at lash point in degrees (intake/exhaust) is 275/280; duration at .050" tappet lift (intake/exhaust) is 208/221; and maximum lift with 1.5:1 rocker ratio (intake/exhaust) is 474/501. Valve lash is zero/zero and lobe centerline is 112 degrees"
Old Oct 11, 2004 | 08:00 PM
comp's Avatar
comp
Thanks didn't have that link
To ZZ4 cam
