solid roller question
Old Oct 25, 2004 | 10:14 AM
hubes's Avatar
hubes
Default solid roller question
is there any advantage to going with a solid roller over a hydrulic roller if I dont plan on spinning the engine over 6k rpm? thanks
Old Oct 25, 2004 | 10:26 AM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Some, but probably not worth the added head ache for only 6000 rpms.
Old Oct 25, 2004 | 10:40 AM
CFI-EFI's Avatar
CFI-EFI
I think it depends on the comparison of two specific cams. As a rule, the solid cam will have more aggressive ramps and more area under the curve. With the self imposed 6000 rpm limit, I would guess this is as much for street use and longevity as anything else. If this is the case, the difference in the appropriate solid and roller cams wouldn't be very significant. With equivalent opening and closing events, the lift would be somewhat less with the hydraulic. The lower lift, alone, will stress the rest of the valve train less and add to the life of all the related components.
RACE ON!!!
Old Oct 25, 2004 | 07:06 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I might add that if you are not going with solid roller that you might want to look at a solid flat tappet instead of hydraulic roller as you can get near the same performance at a fraction of the cost. Nothing beats a solid roller though
To solid roller question
