installed (spark) plug depth - effect on combustion?
Old Nov 4, 2004 | 07:54 AM
Red Tornado's Avatar
Red Tornado
Default installed (spark) plug depth - effect on combustion?
I have AFR (CNC'd with TPIS' program) heads, AFR says the plug reach required for AFR heads is 5/8" (.625"). I'm looking into using shorter header plugs, the Accels are .420", which is .205" shorter.
AFR says these are too short. TPIS says they're fine. Naturally, I'm confused.
What effect will .205" less depth have with combustion & performance?
Old Nov 4, 2004 | 10:03 AM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
I think you're confusing plug length with "reach". The "shorty" plugs don't protrude as far outside of the head to provide more clearance for headers. Reach refers to how far the plug extends into the cyl. If you were to use a shorter reach plug than the heads were designed for it's spark could be shrouded and be further away from where it's supposed to be for proper ignition.
Old Nov 4, 2004 | 10:33 AM
CFI-EFI's Avatar
CFI-EFI
Screw them both into the heads and measure the CC's of the combustion chambers with each plug. You can figure the two compression ratios from all your other data. If the difference is more than .05, I'll be amazed. Time for racing gasoline.
RACE ON!!!
Old Nov 6, 2004 | 08:50 AM
Red Tornado
thanks guys, to the post about confusion on my part - you're right! i finally confirmed the threaded depth of the shorty plugs is the same as standard plugs.
To installed (spark) plug depth - effect on combustion?
By Michael S. Palmer | 2026-06-03 11:00:24
