Converting RW torque to gross engine torque
Old Nov 10, 2004 | 09:40 AM
Brutal64's Avatar
Brutal64
Default Converting RW torque to gross engine torque
Went to the dyno last month and got figures for RWHP and RWTQ. Do the conversion factors used for driveline loss (16%) and accessory loss (20%) giving you gross HP work for torque, or do you need completely different conversion factors.
Old Nov 10, 2004 | 10:24 AM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
HP, rw or otherwise, is calculated from the torque measurement so, yes, the same factors can be used. Keep in mind that those factors are only "ballpark" figures and the actual difference between fw net/gross and rw can vary from car to car.
Old Nov 10, 2004 | 12:34 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Drivetrain 16-18 % loss and depending on your accessories, exhaust and mufflers being the worst drain you can add another 15-20 %. If you are running open headers for example the loss is minimal. Ballpark figure for a Vette running a waterpump, alternator, power sterering and full exhaust might be 35% loss from Gross to RWHP I have seen higher.
To Converting RW torque to gross engine torque
